New DVCPro HD / P2 - Page 12 at DVinfo.net
Old April 4th, 2005, 11:03 AM   #166
Bob, I have a feeling that the new info that was supposed to be coming today was the stuff that was already leaked last week.
Hope I'm wrong about that but I bet I'm not!
Old April 4th, 2005, 11:07 AM   #167
Will the HVX200 be able to shoot SD if a client requires it?
Or can I shoot in HD and easily downconvert to SD for editing?
Pete Wilie is offline   Reply With Quote
Old April 4th, 2005, 11:10 AM   #168
According to the press release (I suppose that's what it was) it will shoot all the different flavors of HD mentioned plus progressive and interlaced varieties of SD. Who knows though, you might get a better picture shooting in HD and downconverting. Then again, with DVCPRO 50 capabilities, you might just be better off just shooting that...
Kevin Dooley
Media Director, Pantego Bible Church
Kevin Dooley is offline   Reply With Quote
Old April 4th, 2005, 11:10 AM   #169
"I have a feeling that the new info that was supposed to be coming today was the stuff that was already leaked last week."
Yes, that was my understanding too.
Jan made a reference on another thread that the picture and format info was the 'April 4th' info she'd been talking about.
"Will the HVX200 be able to shoot SD if a client requires it?"
Not only will it shoot SD, it will give you many options to choose from.
Both DVCPro and DVCPro50 at various frame rates, both progressive and interlaced.
Luis Caffesse
Pitch Productions
Austin, Texas
Luis Caffesse is offline   Reply With Quote
Old April 4th, 2005, 11:38 AM   #170
Will the DVCPro50 have a better SD image than DVProHD?
On the drive vs. PC issue...a drive is smaller, however I am DV Rack addicted and have 2 5 hours batteries for the laptop. Unfortunately, there is no HD DV Rack, yet.
David
P.S.
I have received requests for more footage of this or that, him or her, long into a project (and sometimes after). Having the footage definitely helps.
David Ziegelheim is offline   Reply With Quote
Old April 4th, 2005, 11:41 AM   #171
You know, now that you mention DV Rack, I would think it would be easier to write a DV Rack version for DVCPRO50 or HD, since it is still based on the DV codec, versus rewriting to handle HDV, which is another beast altogether...
I hope DV Rack is paying attention...
Kevin Dooley
Old April 4th, 2005, 11:42 AM   #172
<< Will the DVCPro50 have a better SD image than DVProHD? >>
That's a Jan question, but I would be very surprised if DVCPro HD downconverted didn't look as good as or better than DVCPro 50. Depends on the process, I guess.
<< I am DV Rack addicted and have 2 5 hours batteries for the laptop. >>
I can certainly understand and sympathize with being a DV Rack addict! That's a great piece of software. Hopefully they'll make the leap to HD soon.
<< Having the footage definitely helps. >>
In certain situations such as yours, I can fully understand that too.
Old April 4th, 2005, 11:55 AM   #173
Framerates at SD resolution?
Hi all,
I know that everybody's quite keen on the HD aspect of this new camera. Who can blame them?
I'm wondering, has anyone pondered what kind of framerates if you decide...OK, why would you?...but if you decide to shoot at 480p?
If you can get 60p at res of 720 maybe you could really overcrank at 480? Say 90 or even 100p?
Or am I talking crazy?
Just wondering.
sincerely,
ian
Ian Slessor is offline   Reply With Quote
Old April 4th, 2005, 12:24 PM   #174
30p was the highest progressive frame rate given for SD. Don't know if there will be anything else. I doubt it.
I think shooting DVCpro50 is the best way to go if you want SD. No need for all the extra space, processing etc and it is much less compressed per frame than the HD codec (out of sheer necessity).
Aaron Shaw is offline   Reply With Quote
Old April 4th, 2005, 12:32 PM   #175
I though DVCPro50 supported 10 bit quantization, and DVCProHD supported 8. Which is why I thought the DVCPro50 may have better image.
David
P.S.
Ian, the DV format supports 60i NTSC or 50i PAL. 30p, 25p, and 24p are adaptations of that format. It would not be possible to store an image with a higher frame rate in that format.
Old April 4th, 2005, 02:15 PM   #176
Barry Wan Kenobi
Yes, and it will be able to shoot SD at the best-quality SD you can get for under $20,000.
It supports two different SD recording formats, either DVCPRO (which is the same as DV, basically) and the DigiBeta-quality DVCPRO50, which provides for less compression and twice the color resolution of any DV camera. It's the same format that's used in the $20,000 SPX800 and the $25,000 SDX900.
So yes, SD is not only possible with the HVX, but it'll probably be the best SD you can buy for less than $20,000.
Old April 4th, 2005, 02:25 PM   #177
<<<-- Originally posted by Brad Abrahams : Just saw this posted on dvxuser. A firewire drive enclosure that includes a rechargeable lithium-ion battery with 10+ hours of usage per charge. This would be perfect if the hvx streams the data over firewire:
http://www.macpower.com/productdetai...&catid=311,316 -->>>
But just plugging in a drive won't work. Something at the other end needs to decode the IEEE1394 stream, and write a filesytem.
Aaron
My Website
Meat Free Media
Aaron Koolen is offline   Reply With Quote
Old April 4th, 2005, 02:26 PM   #178
Well, maybe, maybe not... the camera clearly writes files itself, as that's what it stores to the P2 cards... why couldn't it just send those files over firewire to an external drive, same as if you hooked it up to your computer?
Kevin Dooley
Old April 4th, 2005, 02:33 PM   #179
<<<-- Originally posted by Kevin Dooley : Well, maybe, maybe not... the camera clearly writes files itself, as that's what it stores to the P2 cards... why couldn't it just send those files over firewire to an external drive, same as if you hooked it up to your computer? -->>>
Anything's possible for sure! I just find it hard to believe they'll do that. Haven't they just teamed up with Firestore for some thing? What I could imagine happening is some tight integration between the camera and a firestore so they work all sexily together.
Aaron
My Website
Meat Free Media
Old April 4th, 2005, 02:35 PM   #180
<<<-- Originally posted by Barry Green :
Thanks Barry, that was very helpful.
So does this mean the HVX can shoot SD at the 4:2:2 sampling ratios, whereas MiniDV is 4:1:1?
