#16 | |
According to your sig, you already own Panasonic's solution to those shooters. The HMC150/151 is the perfect solution for event-based long form shooters. As far as higher end pros, I tested the SD card hack on the EX1 for a client who shoots for all of the film studios. When I showed them that it works but dropped frames at anything 36fps and higher, they said, "no thanks, we'll stick with SxS cards". I can't imagine P2 users or even high end SxS shooters risking jobs worth hundreds of thousands of dollars of business to shoot on relatively unreliable, cheap, flimsy (in comparison to P2) SDHC cards. Low cost media is not most important thing for most pro shooters, reliability/dependability is. I don't see Panasonic drastically lowering P2 prices anytime soon. Dan |
#17 | ||
The only cards that in theory could match P2 are the newest CF cards, but it's hard for panasonic to guarantee the quality of production outside their world. That said, i don't think Panasonic could charge whatever they want, and for the smaller cams it's a tad expensive for starter. But in every viable business you should charge enough to pay for the gear in x amount of time, or just rent if you some times need to shoot more than say 2 P2 cards can hold. Thats my plan for P2, have 2-3cards, renting if more are needed. Quote:
2. What happens to the last clip? Corrupted and unusable might mean do another run in the chopper or miss a valuble shot. Of course chopper shooting is a bit maximizing the consequences, but some times you end up with pictures that will cost a lot to re-shoot. 3. When putting the hpx170 to overcrank mode, are the pictures from the sdi slowmotion?(maybe i was a bit quick, but thats what i though about.) |
#18 | ||
It just sounds like you're grasping at straws at this point. If Panasonic turned around and said they were going to lower the price of all currently shipping P2 cards by $400 would you now complain that they are too cheap? Would you send them an extra $400 out of good will? Would they no longer be pro? You haven't made a good argument for anything other than stating the belief that "Pro" products are somehow less prone to problems than "consumer" products, which is largely a falsity when you consider the complex electronics in any given device. Is a P2 card more durable than an SD card? Yes. Is a P2 card perfect? No. Is either of those facts the argument or the point that the various posters (and many others over time on these boards) have been trying to make? No. Most of my P2 shooting is limited to the hvx200 and the hpx500, but I'm almost positive the hpx170 puts out whatever it shoots through SDI including slow-motion but it won't look slow until playback. |
#19 | |||
As already pointed out by others, the media cost for many won't be the issue when thousands of dollars are on the line. I just raised the price as i'm moving into buying P2 equipment and usually there are no complaints, except for greedy broadcasters that don't want to pay in the first place... Quote:
No pro don't justify charging whatever they want, but pro in my world mean that the manufacturer should go the extra length to ensure that the quality will hold up to the abuse of pro use. Cf cards are cheap and hold up, can't really see where I stated that pro can't be cheap. What you also pay for is the fact that P2 cards, except the first ones, bought back in the start can still be used with the both the cheap hpx170 or the hpx3700 in avc-i. There are also according to Panasonic headroom for implementing higher bit rates. So P2 might be expensive, but at least in the pro world.....it's possible to protect the investment, but that don't mean it defend the price the the largest P2 cards have. But the best argument is that no sd or cf card available today, i know that cf cards that are fast enough are around the corner, can record the higher framerates you can do with Pana/Sony. Sd adapter in SxS drops above 35ish fps and dvcprohd with higher bitrates i can't imagine would be better, then i also imagine it would have a hard time coping with 720p50 which are what many broadcasters here in Europe aim for as standard. |
#20 | |||
And even if anyone really doesn't trust lower cost SDHC, the beauty to me of an SxS camera is the choice it gives - you don't have to use low cost media, you can equally use top notch SxS cards with the same camera. Choose the media to suit the assignment. A choice you just don't get with P2. Quote:
Yes, you continue to support what has recently been sold, spare parts, memory cards etc for a realistic period, but it would be foolish to hold back new developments for fear of upsetting past customers. |
#21 | ||
As long as P2 grow in size I wouldn't call it outdated as it outperforms all current sd and cf cards and offers the same or better capacity, of course with a price tag. This might go down with more and more P2 users? Who knows....maybe NAB or IBC will bring some new light to the P2 roadmap? One difficult thing with say jumping over to er new standard are who should decide when? Many broadcaster run their gear almost 10 years before replacing it and they expect service and parts for those years. And I suspect broadcasters with billions in their investment pockets have much more to say then us small freelancers.... |
#22 | ||||
You just do not need the complexity and expense of P2 to record pro quality video these days. P2 was a necessary technology to get the speed when being developed, but just isn't anymore. Quote:
I agree they won't natively go for SD or CF for their larger pro gear - far more likely SxS - but as 50Mbs XDCAM-HD422 is a fully approved next gen HD codec, it's likely SDHC/adaptors may still be usable in such cameras. You may choose to use "proper" SxS, but again, the user has the choice. Quote:
I believe a tipping point will come with a full size pro SxS based camera, and at that point Panasonic will have some very hard decisions to make. At the moment it's perfectly true that if you want a high end solid state camera it has to be Panasonic. Don't expect that to be true for too much longer. |
#23 | |
Are you still going to raise your prices? Are you going to still buy "A" series cards, are the "E" series not pro enough? I know my hvx200 will be happy. |
#24 | |
For a rental house though and broadcasters doing 24/7 news the expensive cards till might be the right choice for some users. |
#25 |
It looks like the first hint of the future for camera memory has come;
ProVideo Coalition.com: Camera Log by Adam Wilt | Founder | Pro Cameras, HDV Camera, HD Camera, Sony, Panasonic, JVC, RED, Video Camera Reviews I know, this is just a little hickup, but you don't abandon a technology that has a healthy future. I bet SXS and P2 to SDXC adapters are in the near future.
Panasonic HMC150/Canon A1/JVC HD1/Sony Vegas 8.0c |
