Shooting MOS with P2 and card space. at DVinfo.net
Old November 8th, 2008, 03:00 PM   #1
Hello.
Regarding the HPX170 or 200.
I've been wondering about this one: Let's say you are shooting B roll stuff, and have no need or don't want any sound recorded with the video footage.
1) Can you do this?
2) If it is possible, how much more space/shooting time would you gain by not having the audio part of the video?
3) Even if you don't save much card space, would just turning the audio sound levels to 0 be like turning off the audio?
Thanks.
Jonathan
Jonathan Levin is offline   Reply With Quote
Old November 8th, 2008, 03:09 PM   #2
1. Yes (see #3).
2. Sorry, you're not going to gain any significant amount of video recording time by not recording audio.
3. Yes.
Old November 8th, 2008, 03:13 PM   #3
I don't think you can save data space just by turning off the sound...I may be wrong
Interesting to find this out
Charlie Gillespie is offline   Reply With Quote
Old November 8th, 2008, 05:28 PM   #4
The HPX170 actually has a menu function for shutting off the camera's internal mics. The HVX does not. In either case, the actual audio tracks 3 and 4 are still present in the .MXF file. The data space required should be negligible and it doesn't really matter anyway because there is no way to disable the camera recording them, even if they contain no sound.
Dan
Old November 9th, 2008, 01:26 PM   #5
Thanks fellows.
Just what I was looking for.
It's been so long that I've been thinking about getting a camera, that the 170 came out and it now seems that that is the camera for me, eventually. For now I'm renting 200 for my new video biz. If I ever make enough money, it's the 170. Unless I procrastinate long enough and there is a 175..
Jonathan
Old November 9th, 2008, 04:50 PM   #6
If you have not read it already, you might find this to be good reading Panasonic's HPX170
Dan
Old November 9th, 2008, 08:22 PM   #7
Better than Halle Berry
Yeah you can mute the audio but you cannot record video clips without audio attached and it's not a way to save space. And ever if it were the space saved would be negligible.
-Noah
Noah Kadner is offline   Reply With Quote
Old December 16th, 2008, 01:31 PM   #8
When I record 720/ 24pN and choose not to shoot at 24fps, I record no sound.
Hmmm. I understand the reason for this. But I wonder if it can be used for your purposes?
Try setting your camera to 720/ 24pN, and change the framerate to 22fps or 26fps. My guess is that no sound will be recorded, and the video will look similar to the video you normally record.
-Andrew Burke
Andrew Burke is offline   Reply With Quote
Old December 17th, 2008, 10:45 AM   #9
Yeah there is no sound recorded when you are in variable frame rates but also 26fps is kinda useless if you're not wanting slow motion. And again the savings in recording time might be around 1% across a whole P2 card. Get another P2 card instead....
Noah
