Vimeo - Hidden Beauty Vol1: Southern Oregon Coast - DEMO at DVinfo.net
Old November 3rd, 2008, 05:41 AM   #1
Images: 2
Hidden Beauty Vol 1: Southern Oregon Coast on Vimeo
This is an HD link to a 5 Min demo of a self produced, hour long DVD of the southern Oregon coast. DVD will include GPS locations with Latitude and Longitude, nearest city or location name. With over 4 hours of footage, stock footage will be available for purchase as well.
DVD will be available soon.
Camera: Panasonic HPX500
Format: 720 30pN (60FPS, 12FPS, 30FPS)
Lens: Canon HD KJ13x6BKRS
Tripod: Manfrotto 315MVB2
Head: Manfrotto 519
DP/Camera: Derek Nickell
Camera Assistant: Lisa Brown
Editor: Derek Nickell
Music: Holmes Ives - Rhizae
Derek Nickell is offline   Reply With Quote
Old November 3rd, 2008, 06:46 AM   #2
Always loved the colour quality of the HPX500 and other DVCPro cams.
Some burn out on the flowing water, wonder if you could keep the exposure down during shooting to control the whites and bring up the rest in grading? Are you using factory settings? Check the BBC site http://www.bbc.co.uk/rd/pubs/whp/whp...ic-HPX5003.pdf that has settings for various pro cams. Not sure about this one for the HPX500, but certainly the settings for Varicam and the HDW Sonys give a big improvement in dynamic range, about 2 stops.
Steve
Old November 3rd, 2008, 06:52 AM   #3
Better than Halle Berry
Solid! But yeah highlight clipping is always the trick on digital. It can be mitigated with a nice monitor with vectorscope and waveform capabilities. Also ND filters and polarizer. With the HVX, work with the gamma settings. Finally, erring a bit on the side of underexposure can make the difference.
It's a lot easier to correct for in post than blown-out highlights. Though some plugins I've seen out there will even help those out a lot. For example, check out Captain's Blowout Fixer:
Free Plugins for Final Cut Pro
Noah
Noah Kadner is offline   Reply With Quote
Old November 3rd, 2008, 12:43 PM   #4
Are you willing to give out a little more info on the production ? NLE used ? How did you down-convert to SD ? DVD authoring program ? Thanks, Mark
Added in Edit - seeing your other posts, I'm sure that you must have used Final Cut Pro, but the questions on down-converting and DVD authoring are good. Mark
Mark Donnell is offline   Reply With Quote
Old November 3rd, 2008, 03:04 PM   #5
Images: 2
Right, FCP for editing. Used P2CMS on site to pump out of the 32gb cards, brought into FCP strait from Log and Transfer, exported out to a regular QT movie for the web, QT export to an H264 HD res (1280x720) file for Vimeo. Nothing special.
The DVD was ran back through FCP and broadcast safe was popped on it, exported and ran through Compressor, dumped into DVDSP and burned off that way. Again, nothing special.
Old December 16th, 2008, 01:43 PM   #6
Thanks, Noah.
I am always on the lookout for FCP plugins. Patrick Sheffield and Graeme Nattress sure know how it's done!
-Andrew
Originally Posted by Noah Kadner View Post
...It's a lot easier to correct for in post than blown-out highlights. Though some plugins I've seen out there will even help those out a lot. For example, check out Captain's Blowout Fixer:
Noah
Andrew Burke is offline   Reply
