Video image vs stills at DVinfo.net
Old November 29th, 2007, 01:40 PM   #1
My video images look sharper and more distinctive than stills. Are there any effective ways to optimize the stills. hvx-200 , canon 1dsmkII.
Jack Davis is offline   Reply With Quote
Old November 29th, 2007, 04:09 PM   #2
Then there is something wrong with your 1Ds or you need to invest in better
lenses for it....
Old November 29th, 2007, 04:39 PM   #3
video images vs stills
This was my thinking also. If I read your reply correctly, the still image should be sharper, with better contrast, and have a greater dynamic range than the video.
Old November 29th, 2007, 05:19 PM   #4
Yes, on any given day.
Old November 29th, 2007, 06:26 PM   #5
I had few digital SLR camers and some of the zoom lenses, to me there were some focus issues and I started using prime lenses and issue was solved.
Kaku Ito is offline   Reply With Quote
Old November 29th, 2007, 06:55 PM   #6
Are you just dragging to a time line and expecting the editor to maximize the still in the video time line. You don't say what you are editing in-- or is this a general question about image before it goes into video time line ?
Chris J. Barcellos
Old November 29th, 2007, 07:35 PM   #7
Jack, Could you posibly be compairing a preview low res still from the 1Ds
versus the high res original??
Are you shooting raw and not processing the raw still??
But wow, I'd give a bunch of mula for a video camera that could match a 1Ds
in quality, frame to frame... that'd be one heck of a video camera...
lets just say if you could find a video camera that would shoot in progressive mode as well as the 1Ds then Canon couldn't sell a single 1Ds as everyone would be shooting with the video cam and just extracting the frame...
Old November 29th, 2007, 07:37 PM   #8
still vs video
Thank you Chris! I am editing in fcp6 and yes dragging the still image to the time line. I have gone back and brought some razor sharp still images in and they are soft in comparision to video. When I over sharp the images and increase the contrast, they start to match up with the video. I photograph stills with either med. format or high end digital 35mm and the images are smooooooth and not in any way pixalated. Lower end digital cameras and point and shoots over sharpen images.
My goal is to make the stills look as "video" as possible so that motion can be put into the images. I am looking for suggestions.
Old November 29th, 2007, 07:42 PM   #9
Jack, on the PC side, I will try to resize my stills as close as possible resolution wise to the project settings, in my photo editor. That way, the editor won't do much changing to the image to size it to the project. I don't know if that will work for you in FCP.
Edit: I also know that in Photoshop, they have a filter called video to help the process.
Chris J. Barcellos
Old November 29th, 2007, 07:44 PM   #10
stills
Actually Ray, I have a canon 1dmkIII and am looking at how to shoot and compile the images (I think 11 frames per sec. at high resolution) up to 35 frames and 11 frames per second at med resolution up to 100 or so frames. These are just raw estimated but in the ball park. Any suggestions.
Old November 29th, 2007, 08:09 PM   #11
Jack If your using Photoshop to process the stills then I'd suggest you go to the help file and search under video....
Then see if any of the numerous articles can help you out...
As Chris has said, Its best to resize the stills to the timeline first....
Unless you are going to use keys for pans and zooms....
Old November 30th, 2007, 12:41 AM   #12
ah that is what your doing. Yep, I would recommend resizing of the Photoshop or even iPhoto and bring in to FCP.
Since you have the hires stills then it would be nice if you bring them in little larger and do some subtle motion effects then it will be nice!
