aj hdx900 with sony vegas? at DVinfo.net
Old November 29th, 2007, 01:30 PM   #1
Hello all,
Wonder if you can help.
Here is my current situation. Shooting with Sony DSR F350 - great in good light but awful in low, truely awful.
Thinking about buying AJ-HDX900 (second hand). My wide angle canon sd lens J13 would work with it for the moment, as would my v lock batteries. So I should only need to get the camera body. Am happy with it being tape based. Think P2 cards are fiddely.
Question is, can I use Sony Vegas to edit its footage, I would plan to firewire the footage in from the camera and not use a deck (cant afford one!). Is anyone out there using it with Vegas as the moment? How are you managing?
I am based in the UK but would probably get the camera in the US, as with the current exchange rates, I think I could save a lot of money.
From my research, I think the camera looks amazing, really excited by the prospect of using it.
Your advice would as always be much appreciated!
Sparky
www.sparkymedia.net
Mark McCarthy is offline   Reply With Quote
Old November 29th, 2007, 09:38 PM   #2
Barry Wan Kenobi
The problem is -- how do you plan on getting the footage in? Vegas won't capture it, and there aren't any standalone capture applications either.
So you'd have to either use a Decklink type of card and capture via HD-SDI, which would work, or if you want to go firewire you'd probably need to get Adobe OnLocation (or, if you can find a copy still for sale, DV Rack 2.0 HD). DV Rack would give you everything you need, the ability to capture the footage from tape via firewire and the appropriate DVCPRO-HD codec to be able to edit in Vegas.
Old November 30th, 2007, 04:29 AM   #3
Thanks so much for taking the time out to help Barry. I'll look into those options.
I think going to this 2/3 inch HD camera is the way forward for me for a while. And I think you can pick them up for a decent price used. Do you use a HXD900?
Old November 30th, 2007, 09:07 AM   #4
I understand that DVCProHD codec is not available for "standalone" applications. Better check whether Vegas offer that option - because you won't be able to download anywhere.
I refer you to a previous discussion ...
http://dvinfo.net/conf/showthread.php?t=43582
TS
TingSern Wong is offline   Reply With Quote
Old November 30th, 2007, 11:14 AM   #5
Barry Wan Kenobi
No, I'm primarily on the HVX200 and HPX500, with a Red One due sometime next month.
