#16 | |
But call it 202, 200, 200p, 200mc, they are all the same camera, but different in regions or color system. CCD's, body and lens are the same.
If you don't believe in your film, no one else will. |
#17 | |
#18 |
No waveform. Wish it did then it wold be a no brainer.
#19 |
I believe NEBTEK monitors are available only in the US. In Singapore, nobody seems to carry the NEBTEK monitors. I did purchase the Panasonic LH80 - no regrets. It makes manual focusing on the HVX202 a "peanuts" - no guesswork whatsoever. The only problem is the monitor + AB battery is heavy - and I don't want to risk problems mounting it on the HVX202 handle itself. So - I bring along a very light tripod to attach the monitor only.
#20 |
As far as i know you need to go to Nebtek directly even in the US.
#21 | |
Barry Wan Kenobi
Not for walking around, so much, but for setting accurate critical focus. Although, that's really the only focus assist option the JVC HD100 series has and they seem to get along just fine with it. No waveform on the Nebtek? That makes my decision easy then, I'm ordering the Panasonic. Thanks for looking into 'em! |
#22 |
Barry. I think I will give the Panny red thing another try as I only looked very quickly at it. Today I put the Nebtel up on a shoot with the Panny 17" and the older 8.4". I was a bit worried about the bluish image on the nebtek this time, so I need to look again at them. Also I felt the advantage of that waveform in the field - Damn, its complicated again.
- Lenny |
#23 |
I found the marching red (IN FOCUS) indicator in the LH80 really, really very good. I can't see how people can hate it - especially when using it with HVX202. The LCD (viewfinder and swing out) on the camera is simply not sharp enough to tell if the critical focus is achieved. Only when I plugged in the LH80 and turned on the "focus in red" function - like what I said previously - ZERO guesswork. It is simply magic ... if you haven't tried it before, you never know what you are missing. Granted it does not work that well on moving objects - but, it allows you to accurately determine where the lens is focusing upon by observing the surrounding areas which are not moving.
