Shooting widescreen HVX-200:: Help needed. at DVinfo.net
Old September 18th, 2007, 06:49 PM   #1
Here's my issue. The HVX-200 in 720p mode will only do a 4:3 letterboxed picture with black bars. I want to have a full 16:9 image that will display natively on a 16:9 screen. I'm having one hell of a time finding the option in the menu that would set the camera up this way. I figured it would be totally obvious, but this does not appear to be the case.
Can anyone point me in the right direction?
Noah Couchot is offline   Reply With Quote
Old September 18th, 2007, 08:03 PM   #2
In HD the output is true 16:9, which will necessarily look stretched on a standard 4:3 monitor unless the monitor itself can correct the image, with letterboxing. Output to a true 16:9 monitor, a 720P signal will look correct (unless the monitor itself has a sidebars or letterbox function that can be turned on and off).
youtube.com/benhillmedia
linkedin.com/in/benhillmedia
Benjamin Hill is offline   Reply With Quote
Old September 18th, 2007, 08:50 PM   #3
Yes, that's definitely how it should be. But I'm having a little difficulty setting up the camera.
Can you tell me what settings I need to have in order to have true 16:9 widescreen? I don't have the camera in front of me, or else I'd describe the settings I have currently.
Old September 18th, 2007, 10:35 PM   #4
Barry Wan Kenobi
In 720p mode, or 1080 mode, or "squeeze" mode, the HVX is always full 16:9.
The only time you get 4:3 is if you shoot standard-def 480 mode and choose "norm" or "letterbox". Anything else ("squeeze", 720, or 1080) will always be full 16:9.
Barry Green is offline   Reply
