Varicam to SRW-1 at DVinfo.net
Old September 13th, 2007, 04:13 PM   #1
Varicam to SRW-1
If I were to record on the Varicam at say 48fps, could I get the signal into a SRW-1 (recording at 24PsF)? I know the varicam flags frames, but could the SRW remove those excess frames? (I know they're made by two different manufactures.)
Andrew Mcarrick is offline   Reply With Quote
Old September 15th, 2007, 06:29 AM   #2
Go Go Godzilla
Images: 15
You should ask a Sony rep about this; I've personally not used the SRW-1 but have worked with other production facilities that do. Since the Sony is working in HDCAM/SR and is designed to work with the F900 series cameras there's nothing to indicate it will play well with any other manufacturers camera system.
Robert Lane is offline   Reply
