The rubber has come off the SD cover. How can I attach it? at DVinfo.net
Old January 5th, 2019, 12:10 PM   #1
Hi,, I don't know if it is the heat problem but the rubber of SD cover came off. It is around 2cm and I don't know as I can glue it. I tried with a yellow mastic but it looked like water. It was impossible to glue it. The mastic was not able to glue the rubber, even it seemed that I had put water instead of the mastic. Yet that mastic is a formidable glue. Do you have some suggestions? Thanks
EDIT: I used it: https://www.amazon.it/UHU-B2_0645039...ce+superchiaro
A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/channel/UCdv...DrZCaaw/videos
Adriano Moroni is offline   Reply With Quote
Old January 5th, 2019, 01:56 PM   #2
Re: The rubber has come off the SD cover. How can I attach it?
Perhaps Gorilla Glue would do the job.
https://www.gorillatough.com/product...-gorilla-glue/
Best Regards.....George
George Dean is offline   Reply With Quote
Old January 5th, 2019, 04:18 PM   #3
Hi George, did you get experience witht hat Gorilla glue? Someone told me the plastic of a camera isn't real plastic but polietilene or polipropilene and there are no glues can attach it. But I don't know it.
I thank you!
Old January 5th, 2019, 06:39 PM   #4
Why don't you see if your dealer can get a proper replacement part that will then keep the weather sealing of the camera.
Old January 5th, 2019, 07:00 PM   #5
Do you know if Panasonic can replace it with Warranty? I have it for one year.
Old January 5th, 2019, 07:35 PM   #6
I do not know . Ask
Ron Evans is offline   Reply
