#61 |
Re: First Impressions of the GH5
Hopefully I will have my GH5 next week and can check myself a few things. Auto focus and the issue of audio being delayed at the start of record. In view of the several autofocus example above I think Max either has a bad unit or continues to set it up incorrectly . None of these videos just use the standard auto focus either, always the customs settings.
I believe PhotoJoseph was also recording internally as he gave instructions on HDMI output settings so that he could record 60P internally and 30P externally as his recorder could not record UHD60P. So yes he was recording internally as well as externally. EDIT: Just read that he did only record externally and I must have mistaken his HDMI settiing incorrectly. We will see what else emerges. Still I will check myself next week !!! Last edited by Ron Evans; April 7th, 2017 at 07:36 AM. |
#62 |
Having read the manual several times now waiting for my GH5 to turn up there are so many parameters that can be set that I am beginning to think Panasonic should have provided presets in the movie mode that completely control all settings. Also provided a lot more explaining how to set up.
This will be my first Panasonic bought for UHD60P only. I normally shoot 3 or 4 camera multicam all with Sony video cameras and they are all in manual focus !! However 3 of them will be set with touch focus as needed and that is how I will use the GH5 too. So for me hunting is not an issue as the GH5 will be in manual focus but getting it to lock on touch focus will be. We will see hopefully next week. |
#63 |
It just amazes me that people will ignore all the evidence of good GH5 CAF and focus solely on Max's test. I posted 4 examples of good GH5 CAF, 2 of which mirror what he did and it couldn't be more obvious my results were 180 from his. I also did a candid mall video, shown below, because I've shot in this same mall with my A6300 and it often failed, focusing on the background and ignoring the subject or simply not holding the subject when it did focus. Although there was a bit of hunt in a couple of clips, there was nothing like the outright failures I have gotten with my A6300.
For those that have any interest in objectivity, all I used in the 4 videos I've posted, was central area focusing with all other AF settings at default. I never bothered with speed or responsiveness. I think some are making this more complicated than it needs to be. But hey, people will believe what they want to believe. It's fascinating to see. |
#64 |
To be honest, I watched PhotoJoseph's video and the autofocus is plain unusable, there is a constant hunting going back and forth or missing focus. I might have used it if it was good and only in situations where I can reshoot but how it looks no, no thanks, not for me.
#65 |
#66 |
Noa, I used CAF. If I had done that with the A6300 I would have gotten similar results or, more likely, the A6300 would have ignored the subject and focused on the sign as has often happened to me. With that said, most people would focus on the subject and not the background. The subject was fine.
However in reality, most of us don't use CAF with any camera of this ilk. In a shot like that, if I was doing it 'for real', I would have used lock on AF and would have entirely eliminated the hunt. Totally. If not using MF, that's how I would have shot that scene. But that wasn't my intent for this or any of these tests. My point in the video was a) to show how much better the results were than Max (no comparison, his were a total blurry mess) and b) to see what the worst case scenario was using CAF. |
#67 |
I"ll have to see it myself once I get my gh5, but it's not a feature I am looking forward to unless it proves to be spot on with tracking a subject that walks towards me, that's the only reason I would use it, if it is any good.
#68 |
Do you often shoot someone walking towards you?
#69 |
#70 |
Yes, at every wedding that I shoot, the most critical moment is when the bride and others walk towards the altar where I am standing.
#71 |
Just picked up my GH5 this afternoon so have only just had a quick look at it. Heavier than I though as this is the first time for me moving from video camcorders. It is about the same weight as my FDR-AX53 I think. Did a quick auto focus check. With Custom AF " OFF " continuous ON , the focus moves a little slower than the AX53 but gets there and changes just fine from real closeup to about 15 feet away in about the same time as the AX53. Playing with the custom settings I can get all the same issues that have been reported !!!
Over the weekend I will shoot some comparitive video against the FDR-AX1 in UHD 60P , the only reason I got this camera. Will test auto focus of both too as I know the Sony is not good as it tends to decide what it want in focus !!! |
#72 | |
#73 |
I'm far from an expert, but one thing I noticed about that video is the deep depth of field, likely the result of a small aperture, Combine that with lots of people moving within the focus area and it's no wonder there's hunting going on. These are shots that IMO call for manual focusing.
#74 | |
Lots to play with and will take some time to full understand. |
#75 | |
