GH4 and VLog-L tested by Camera Store at DVinfo.net
Old April 13th, 2015, 12:34 PM   #1
Its called VLog-L.
They also tested Anamorphic, but say VLog-L will not be part of the upcoming firmware release.
They say its better in skintones and highlight roll off handling.
Ted Ramasola
http://ramasolaproductions.com
Old April 20th, 2015, 03:21 PM   #2
Re: GH4 and VLog-L tested by Camera Store
Looking forward to the release of Vlog L. Gaining an addtional 2 stops of latitude is welcome.
CHeck out this video with early Vlog and anamorphic fov.
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old April 22nd, 2015, 06:26 PM   #3
What lenses did you guys use? And can you tell us more about your workflow?
Visit me and my work at www.artofduke.com
Brian Duke is offline   Reply With Quote
Old April 23rd, 2015, 10:21 AM   #4
Hey Brian,
Right now I am a one man band, (A dept. of 5 was reduced to just me.) That sucks, however I can for the most part dictate my own workflow based on the project and keep options open for my NASA customers to use footage in a flexible manner. With that in mind, I convert to ProRes 4:2:2 and Prores HQ from source footage from Panasonic AF 100, Sony AX 1 4k, and of course the GH4 with Shogun monitor recorder in ProRes HQ. I am pretty much NLE agnostic now except I have been posting more in FCPX since their media management has gotten better. Lots of plug ins help me build templates easier since I don't have a motion graphics person anymore. But still edit in Avid on long form projects. I also now shoot 70% in 3840x2160p, 23.98 fps.
On the lense side I have a mix of cheap lenses mostly Panasonic Lumix, (20mm, 14-140, and 15mm f2.5), a Canon EF 50mm 1.8, an 85mm 1,8 and a Rokinon 35mm 1.4. I have rented a Zeiss CP2 in the past.
But I am most excited about V-log L for the GH4 and only recently have been using LUTs with the Shogun.
(read Adam Wilts article on home page) I downloaded a Vlog to Rec 709 lut from the Pansonic varicam site it improved the overall look of CineD flat footage a lot. I would give a link but it just goes to the Main Varicam Page/ VariCam 35 | VariCam | Panasonic
You can get the Vlog to Vlog 709 LUT in the downloads section.
Overll, budgets are tight, so just trying to push as much quality out of cheap cameras as much as possible.
