GH5 Wish list (read for a tip on how to do dual audio on GH4!)
It's always fun to speculate on what's coming next, so here are some of the things that I really hope to see in the GH5:
1. Relocation of the Playback button to the right side of the body for single hand access (or at least allow the function to be mapped the Fn buttons) 2. Relocation of the headphone port to the AV OUT/DIGITAL port, or to the location of the flash remote port so that the LCD can be angled in any position, unhindered, while using earphones 3. Independent auto audio gain and manual control for each audio channel, Left and Right. I use a tiny channel splitter (Nexxtech Audio Separation Adapter | Other Cables & Accessories | Ratings & Reviews | TheSource.ca) to record 2 audio sources simultaneously and it works great, except when 1 of the 2 sources suddenly gets loud and my GH4 auto compensates on both the L and R channels instead of just the channel in question. For example, when recording live performances, I set the L channel to my wireless transmitter to record the music directly off the soundboard, and the R channel to my mini shotgun for ambiance (audience cheering, etc). If the audience suddenly bursts out in applause or someone shouts during a performance, my GH4 correctly compensates for the audio surge in the R channel, but unfortunately also dips the level of the L channel, resulting in an unwanted dip in the recorded music. Fixing this, advertising the new functionality and perhaps even providing a mini adapter in the box (or selling one separately) would set the GH5 as the first photo camera to allow proper recording of 2 separate audio channels! 4. 4k at 60fps 5. Ability to toggle the "Ex. Tele Conv." function on/off while recording. This would allow users to zoom in to a performance, for example, without breaking the recording of audio or sync with other cameras. 6. Intelligent flash pop-up button that doubles as a flash control when pressed again after the flash is already deployed. For example, pressing the button again could bring up the 'Flash Adjust.' settings 7. Option for Auto Electronic Shutter Off when flash is deployed. To save my shutter, I set my Electronic Shutter to 'on' for doing time-lapse photography. Unfortunately, it's a real pain to be unable to quickly take a flash photo on a whim because of this, requiring the user to find the 'Electronic Shutter' option in the menus and turn it off before the flash can fire. An intelligent auto setting would be extremely useful, whereby Electronic Shutter is automatically and temporarily set to 'off' while the flash is deployed! 8. 16MP sensor. Please don't add more pixels at the expense of low light performance! 16MP is the perfect balance of resolution (allowing 1:1 4k recording) and pixel size. 9. Custom Menu. Please add a custom menu tab to the menu, where users can add and sort any of their most commonly used menu items. The GH4 is all the better for having so many configurable menu settings, but this comes at the cost of difficulty to remember to location of specific items. Allowing users to bundle their most used settings in a single custom menu would be incredibly useful! 10. Relocate 'DISP.' button to avoid inadvertent presses. I can't remember how many times I've changed my display mode by accident while tightly gripping my GH4. This is a real pain! Please fix this problem by either: relocating the button (perhaps to the current location of the Playback button) or allowing the button to be disabled in the menu settings. 11. User selectable display settings. If a user only ever wants to toggle between 2 display settings, for example, why force them to toggle through all 5 options every time? A simple solution would be to allow users to turn unwanted display settings off in a new menu option. 12. Larger 3.5" LCD, or at least 3.2". Not sure if 3.5" could fit inside the current flip-out enclosure, but it sure would be nice. I copied the text above from an email I sent to Panasonic's Senior Engineer, Mr. Robert Kozlarek. If you agree with any of the suggestions above, our only hope of seeing them is to speak up and let Panasonic hear us by contacting them. Mr. Kozlarek's response to several of the points I requested in past emails was that too few people are making the same requests for consideration. That doesn't mean these improvements aren't needed. It just means most users are too complacent and not vocal enough to bring issues to Panasonic's attention. Please do your part and let Panasonic know what you want to see in the upcoming GH5! Agree? Disagree? See something missing in this list? Please share! |
Re: GH5 Wish list (read for a tip on how to do dual audio on GH4!)
UHD at 50P would be great.Internal 10 bit recording on newer SD cards would be nice. Same case - Thats it!
Can I add.... SUPER35 SENSOR to the list? :)
Need to rent camera gear in Vancouver BC? Check me out at camerarentalsvancouver.com |
I definitely think that adding a second Venus engine to the GH5 should allow UHD 60p. I'd also like to see 1080 up to 120fps.
4K IPB at 200Mbps. All-I 4K up tp 30p at 400Mbps (Intra at 60P would need to be a whopping 1200Mbps to be worth doing...cannot really see that.) This might require sizing up the GH5 to a slightly larger body to accommodate CFast. That might also make it possible to add a second Venus engine. 422 internally at all recording options. The bitrate is already there for crying out loud. With a second Venus engine, might be nice if that allows 10-bit and internal 8-bit recording simultaneously. V-Log Make the YAGH smaller so that it's more battery-grip-sized. Able to be powered internally by a Panasonic battery or, at the very least, a DC-in instead of 4-pin XLR as that is a ridiculously oversized connector. Right-angled DC-In to Power-Tap with a cable included in the purchase of the YAGH-2. 2 6G-SDI outs and a full-sized HDMI out. Make the YAGH-2 able to send a 12-bit raw video signal out to a Shogun for recording in CinemaDNG. This would require the YAGH-2 to have a larger connection base to the camera instead of the YAGH-1 which is just a simple HDMI->SDI converter box. In fact, if at all possible, the YAGH-2 should not connect to the side ports of the GH5 at all. Internal guidelines to turn on for different aspect ratios. C4K at 23.98, 4:3 crop modes for using anamorphics. |
#5 |
I would hate to have a super 35 sensor - for my use like tele and macro work, I do not need a shallow DOF. I have other cameras with super 35 sensor when that is needed and there are other fabrics making that - and please keep the MFT mount....
#6 |
#7 |
The shallow DOF is so yesterday. Try watching a 4K film or even a 1080p and not be put off by the amount of out of focus shots. Shallow DOF is ok in small doses, but is so overused now, as are droneshots.
Eyes are a deaf man’s ears. Ears are a blind man’s eyes |
#8 |
Shoulder Mount with a proper viewfinder, ND wheel, and Anton Bauer battery mount....4k, 60P, global shutter, etc...
#9 |
#10 |
Get a dedicated camcorder. The GH4 (3) is lightweight and portable, an ideal B roll camera for tight spots so why clutter it with all that scaffolding (shoulder mounts etc.)
#11 |
Pierre and Gary nailed it.
#12 |
Not Joking, I own two GH3's, soon to be sold for a GH4. I come from a shoulder mount background, and all that rigging to make a DSLR a proper camera is a pain.
I agree it's not the ideal camera for my main purpose or shooting style...just hoping for a bigger brother to have as an A-camera, and the smaller version for OTF's and steady cam...have to plant the seed for the companies to listen. |
#13 |
#14 |
If there was a thread to make requests for a proper m4/3 shoulder mount camera I'd make them there.
My apologies for hijacking the thread. |
#15 | |
What about those who like the GH4 also for its stills side? A shoulder mounted photographic camera is a poor form factor when you want to take photos. |
