Stills with the GH4 at DVinfo.net
Old June 6th, 2014, 10:14 AM   #1
Stills with the GH4
In my setup with the GH4 shooting stills I am making these assumptions when shooting RAW.
1. Photo Style is of no consequence because RAW allows large parameters of manipulation and baking in a picture style would limit those parameters.
2. The best Aspect Ratio is 4:3 because this uses the largest portion of the sensor.
3. When shooting stills in RAW does Highlight/Shadows, i. Dynamic and i.Resolution, have any effect? I am assuming that they don't.
4. Color Space, SRGB or Adobe RGB. Thoughts please.
Thanks for your input
Kent
Kent Jakusz is offline   Reply With Quote
Old June 6th, 2014, 02:09 PM   #2
Re: Stills with the GH4
Raw or raw. Not RAW. It's not an acronym.
I believe, depending on how the application interprets the raw data, that the Photo Style will give you a starting base when you load it into your photo software, but you are, of course, free to change everything about the image after that.
That is correct.
That is correct. This is for video and JPEG stills only. You can adjust these settings within the software that are you using to process the Raw image and get the same effect.
sRGB is more of a standard, and Adobe RGB is supposedly slightly better in how it preserves information from the image. Personally,. I would stick with the standard.
More in depth here.
Old June 6th, 2014, 04:06 PM   #3
Thanks Gary;
I find Panasonic's Owners Manuals incomplete.
One other question. Is there any way to follow focus on a flying bird or other moving object when in burst mode? Unlike the GH3 the GH4 allows the photographer to keep a moving subject in the frame but I can not figure out how to keep the focus area visible. Can the GH4 refocus between shots in the burst mode?
Thanks Again
Kent
Old June 10th, 2014, 04:44 PM   #4
It can;
Burst mode must be in M or L (Rec Menu 5)
AF switch to AFC
AF mode to 1 area
Constant Preview (Custom Menu 5) to Off
