Gh4 viewfinder extension? at DVinfo.net
Old June 5th, 2014, 03:37 AM   #1
Has anyone found a gh3 or Gh4 viewfinder extension? The EVF Is good - it'd be great to have an upward facing extension that also had a bigger eyecup. I know the Zacuto could be stuck to the LCD but don't fancy that.
Mark Slocombe, CreationVideo
http://www.creationvideo.com
Mark Slocombe is offline   Reply With Quote
Old June 5th, 2014, 10:40 AM   #2
Re: Gh4 viewfinder extension?
XP PhotoGear VF-4 LCD Viewfinder
I was looking at this or if I could find a Varavon gh3 will work but cant find them.
Brent Kaplan is offline   Reply With Quote
Old June 5th, 2014, 06:58 PM   #3
Varavon made a great viewfinder loupe for the GH3 but it seems to have disappeared from their web site. They make other viewfinder accessories that may work.
::::Welcome to VARAVON ::::
Old June 8th, 2014, 02:39 PM   #4
Varavon doesn't make the GH3 loupe anymore. I tried the Carry speed VF-4 which I THINK is just a rebranding of the XP Photogear. Its too big to work if you're mounting the camera directly to the tripod plate. Some kind of spacer required and then you will need to find a way (tape would probably work) to block the light leak at the bottom.
Old June 8th, 2014, 06:29 PM   #5
This version is made for MFT cameras, the other one featured on PNC is for DSLRs including larger ones like the 5D MkII/III.
Be sure to watch the video to see how it works.
http://www.photographyandcinema.com/...cd-view-finder
Old June 9th, 2014, 06:53 AM   #6
Too bad about Varavon. The GH3 loupe could swivel up as opposed to the stuck to back viewfinders like the Zacuto Zacuto's First Look: The Panasonic GH4 | Zacuto USA. The other Varavon accessories are attached to the back as well but some have a top door so you can peer in from above. Not ideal at all.
Old June 9th, 2014, 03:11 PM   #7
I was able to get the GH2 version of the Varavon to work pretty good on my GH3. I did have to make a small mod (add a new 1/4 hole) in the mounting plate. As it was the Viewfinder cutoff the OLED on the right side just a bit.
And of course the Varavon renders pretty much useless the headphone jack and the HDMI out for sure.
It is kinda cheap in many ways ....the diopter adjustment is a joke...and the positions tightening knob needs to slip a bit better maybe a nylon washer would do the trick...but that being said I have enjoyed using it.
Amazon.com : Varavon LPEXSGH2 Loupe EX with Supporter : Photography Loupes : Camera & Photo
Mark Pleasant is offline   Reply With Quote
Old June 9th, 2014, 08:01 PM   #8
I had a Varavon for the GH2 - just drill another hole and you're good to go
Varavon Loupe EX-Supporter for Panasonic GH1/GH2 VALU-LPEXSGH2
Mike & HDMI out are fine but headphone access is only possible when the screen is level
Gh4 viewfinder extension?-20140610_120822.jpg   Gh4 viewfinder extension?-20140610_120850.jpg
Cheers - Paul M.
www.perbenyik.com
Old June 12th, 2014, 01:26 AM   #9
Cheers for gh2 model info - Varavon confirm to me the gh3 / gh4 is discontinued.
Old June 12th, 2014, 03:38 AM   #10
Weird that they stopped producing that loupe, with the gh4 having the same shape as the gh3 they easily could have extended sales, glad I got mine in time then :)
Old June 12th, 2014, 05:01 AM   #11
I just filmed a two camera interview yesterday with my GH2 and GH3 and I was thinking of this thread while standing over the two cameras which were set at chair height. The Varavon loupes were perfect as I could look down at the images but also flip the diopter on to check focus. This would have been highly uncomfortable with the other viewfinder extensions available and I would have had to been seated to operate both cameras. Even with the diopter flipped open, the shade offered by the loupes are always a big help. The interview lasted 75 minutes.
I am going to contact Varavon to send a suggestion that they should reconsider. The GH4 is generating a lot of interest so they might have some sales opportunites that perhaps the GH3 wasn't getting them. Also I stored the GH2 loupe improperly after a shoot and the eyepiece is loose, hopefully they have some replacement parts.
Old June 13th, 2014, 02:46 AM   #12
I use the Vavaron Loupe on my GH3 and although some of the build quality is questionable the ability to adjust the angle is fantastic and I love using it, they really need to manufacture it again.
www.tvv.co.uk
Chris Gillooly is offline   Reply With Quote
Old June 13th, 2014, 08:17 AM   #13
When they told me the GH3 loupe was no longer available I responded by saying that I thought they should bring it back, that others would also want to buy it. Hearing from others can only help. Their email:
ok at varavon.com
Jase Tanner is offline   Reply
