Slow motion on GH3 at DVinfo.net
Old October 2nd, 2013, 11:58 AM   #1
Slow motion on GH3
The GH3 will shoot slow motion as slow as 40%. My question is; would it be better to shoot at 60p and apply slow motion in post with Adobe Time Warp or Twixtor?
Jim Snow is offline   Reply With Quote
Old October 2nd, 2013, 12:13 PM   #2
Re: Slow motion on GH3
You should use that only if you need slower slow motion than what 60p gives you (i.e. If you wanted to emulate 120fps).
Old October 2nd, 2013, 01:17 PM   #3
I slow 50P down by 50% in post and get smooth motion, so I guess slowing down 60P 60% should result in somewhat the same result. As I see it no twixtor or timewarp should be needed.
Old October 7th, 2013, 09:28 AM   #4
In P.P. CS6 I typically modify/interpret 60p footage as 23.976 fps which is usually slow enough for most purposes. I've used time warp also when i want to slow it down more although that can add artifacts.
Duane Adam is offline   Reply
