inter-frame / intra-frame question. at DVinfo.net
Old June 23rd, 2013, 10:35 PM   #1
I have a inter-frame / intra-frame question.
The BBC requires a of minimum of 50Mbs inter-frame or 100Mbs intra-frame.
I've read the GH3 will record 72Mbs intra-frame... but after hacking will the camera record 100Mbs intra-frame or more?
Also, can it be hacked to record 50Mbs inter-frame.
Thanks...
Bill Kerrigan is offline   Reply With Quote
Old June 23rd, 2013, 11:29 PM   #2
Re: inter-frame / intra-frame question.
The GH3 already records 50mb/s interframe as a .mov, as well as the 72 intraframe - no need to hack.
Chris Duczynski is offline   Reply With Quote
Old June 24th, 2013, 03:36 AM   #3
Thank you Chris...
Old June 24th, 2013, 08:43 AM   #4
Last I heard the BBC specs 422, & the GH3 only records 420.
Bern Caughey is offline   Reply With Quote
Old June 26th, 2013, 08:12 AM   #5
Quick question before I order my memory card for it - what do you guys recommend that can deal with 72mbps? Under SDXC I see class 10 cards, 64GB, for about $100. Will those be enough or do I need to spend more (i.e. Sandisk Extreme 45 MB/s)?
EDIT: Ordered it already since the online store would have closed in 40 minutes, and I need it asap for a wedding on saturday. Ordered the Sandisk Extreme 45MB/s as I found it at a good price ($117 shipping included), will get back to you after I test it on the GH3 with the highest birate possible! Should be good enough, right? Considering the card does 45 MB/s and the camera records at 72 Mb/s (9 MB/s).
Luc Spencer is offline   Reply With Quote
Old June 27th, 2013, 09:40 AM   #6
I think we do. 72 is not nearly enough for for all-intra. For GH2 they were using 200. Basically all-intra needs a lot more bandwidth.
Ben Edwards is offline   Reply With Quote
Old June 27th, 2013, 12:58 PM   #7
72 intra sometimes doesn't look as good as 50 inter.
William Hohauser is offline   Reply
