Duplicating Slides at DVinfo.net
Old May 16th, 2013, 04:45 PM   #1
Duplicating Slides
Anyone have and experience duplicating 35mm slides with a GH2? Anyone set up a rig to do such a thing?
D
Dennis Vogel is offline   Reply With Quote
Old May 17th, 2013, 11:36 AM   #2
Re: Duplicating Slides
You are probably better off finding a slide scanner or a regular scanner that has a slide attachment.
Old May 18th, 2013, 11:49 AM   #3
Yeah, that's another option. I have a scanner that is going bad. I've sent some slides out to be digitized but I still want to be able to do some myself. Anyone have a recommendation for a good scanner that won't break the bank?
D
Old May 19th, 2013, 08:01 AM   #4
I did a few negative scans by placing them on a very low-intensity light table I've had for years and shooting them with a perfectly stabilized macro lens, then inverting in PS... slides wouldn't be that far off. Takes a fair amount of fiddling, and may or may not be more trouble than it's worth depending upon how many slides you have to deal with.
www.mcbob.tv
Kevin McRoberts is offline   Reply
