Question: Will the GH3 be NTSC/PAL switchable? at DVinfo.net
Old September 25th, 2012, 12:32 AM   #1
Can this be officially confirm please?
Lee Mullen is offline   Reply With Quote
Old September 26th, 2012, 04:39 AM   #2
Re: Question: Will the GH3 be NTSC/PAL switchable?
Google will tell you in 5 seconds, try it sometime, its quite handy!!!!!!!!!!!!
DMC-GH3, H-HS35100 | Press Release | LUMIX | Digital Camera | Panasonic Global
Colin
Colin Rowe is offline   Reply With Quote
Old September 26th, 2012, 08:51 AM   #3
If it isn't in the released specs on the GH3 website then chances are nobody here is going to have a solid answer until the camera actually comes out. You may be able to find somebody out there talking about it but honestly a lot of the talk is pure speculation at this point. So unless it is a written final word from Panasonic you have to treat anything as speculation.
Old September 26th, 2012, 09:04 AM   #4
The specs seem to say yes but there is an asterix next to the PAL specs that says that you can only record up to 30 minutes in European areas. (This is due to an EU trade regulation that taxes video cameras differently than still cameras, apparently recording less than 30 minutes denotes a still camera.) Does that mean that cameras sold in Europe have the recording limit but not the cameras elsewhere? Or does that indicate that PAL is only available to cameras sold in PAL areas. Not easy to say right now as no one has used the finalized camera with the finalized firmware.
Also Google doesn't always work the same around the world, censorship issues.
Old September 26th, 2012, 09:23 AM   #5
Assuming this camera is hackable, there will be an option to remove the 30 minute limit even if you opt to keep the OEM firmware.
Don Litten is offline   Reply With Quote
Old September 26th, 2012, 11:41 AM   #6
I have the feeling it will be locked as the GH2. I'll be pleasantly surprised if otherwise, but don't have high hopes for it. Remember that it's primarily a photo camera with a very good video implementation. If you need the ability to switch formats I'd consider a pro camcorder, not a DSLR.
Regards!
IvI
Ivan Hurtado is offline   Reply With Quote
Old September 26th, 2012, 01:54 PM   #7
On B&H doesn't say for sure http://www.bhphotovideo.com/c/product/892456-REG/Panasonic_Lumix_DMC_GH3_Mirrorless_Digital.html
Cristian Adrian Olariu is offline   Reply With Quote
Old September 26th, 2012, 04:47 PM   #8
Very true William, but its always a good place to start
Colin
Old September 26th, 2012, 05:53 PM   #9
For what it is worth, the GH2's spec chart is organized in the same way as the GH3's - with the NTSC and PAL numbers separated. That camera was sold in two separate non-switchable versions, with no OEM video recording time limit for the NTSC version. My guess is that the GH3 will have separate non-switchable NTSC and PAL versions - as did the GH1 and GH2 before it.
Cheers,
Bill
Hybrid Camera Revolution
Bill Bruner is offline   Reply With Quote
Old September 26th, 2012, 08:32 PM   #10
Regards!
Thanks. My Canon 600D and 650D being consumer/prosumer cameras do allow PAL/NTSC choice, so I disagree with your last remark.
Old September 26th, 2012, 08:33 PM   #11
Why use google when I have you!! You are very handy!! :D
Old September 26th, 2012, 08:34 PM   #12
This was my point to Colin!
Old September 27th, 2012, 04:34 AM   #13
I would be willing to bet that NTSC and PAL are two different cameras.
If you go to Panasonics USA spec page for the GH3:
Panasonic DMC-GH3KBODY - NEW! LUMIX GH3 Body Only, 16 Megapixel Digital Single Lens Mirrorless Camera (No Lens) - Technical Specifications
You will see they never reference PAL or PAL frame rates.
Bill Koehler is offline   Reply With Quote
Old September 28th, 2012, 03:31 AM   #14
True. And I have no doubt Panasonic will price the PAL version to the max as has always been the case with almost all of their video-capable devices.
Wacharapong Chiowanich is offline   Reply With Quote
Old September 28th, 2012, 11:48 AM   #15
Looking at that Panasonic product info page, I also found this:
"*3 Motion images can be recorded continuously for up to 29 min 59 sec in European PAL areas."
Which implies NTSC cameras don't have that limitation. That is huge and is one of the first things I would test for.
