Wireless mic with GH2 at DVinfo.net
Old April 15th, 2011, 09:00 PM   #1
Has anyone used a wireless mic with a GH2? I just hooked up mine and the peak level goes into the red on the monitor in the GH2. The output level of my wireless receiver is not too high. I even set the level in the camera to zero in the menu with no change. It is just fine on my EX1R. Am I missing something? The manual has nothing to say about this.
Jim Snow is offline   Reply With Quote
Old April 15th, 2011, 10:01 PM   #2
Re: Wireless mic with GH2
What model wireless?
John Griswell is offline   Reply With Quote
Old April 15th, 2011, 10:05 PM   #3
Sony UWP-V1
Old April 15th, 2011, 10:21 PM   #4
Hey Jim...completely off topic (I would have PM'd you but I can't find a way on this forum)
I was looking for an earlier post of yours on downconverting HD to SD for DVD authoring.
I use Edius 6 and can export to uncompressed AVI. I have been using Procoder 3 but I am still getting some jaggies.
What is your process again?
Jim
Jim Forrest is offline   Reply With Quote
Old April 15th, 2011, 10:36 PM   #5
Jim, One of the easiest ways to do this is to use TMPEGEnc. Just render out to Canopus HQ and then open in TMPEGEnc and resize. Procoder is a great encoder so you may want to just resize in TMPEGEnc and then render your MPEG with Procoder.
Old April 15th, 2011, 10:39 PM   #6
Jim, I've used the Sony with good results, can't understand your issue, sounds very problematic, wish I had a solution.
Old April 15th, 2011, 11:16 PM   #7
I've been using a Sennheiser EV100 G2 system. On the camera side, it's as low as it goes. On the receiver side, I adjust AF OUT to about -24 to -30 to get good levels. That same receiver setting on my Z1U or HVX is far too low (typically use -12). Must simply be a lot of internal pre-amp going on.
In testing, I've noticed that the level meters in the camera hit the first red mark right around -6, and the second around -2... as tested by droning into the mic until that level was just barely reached (super scientific n all).
www.mcbob.tv
Kevin McRoberts is offline   Reply With Quote
Old April 16th, 2011, 06:05 AM   #8
Yeah I am using TMPGEGEnc 5 now and still not too happy. What size did you resize? I was impressed with what you did with the cat video.
Seems that getting HD to look good in SD on a DVD is quest for most of us. Maybe I should start a new thread for this since this is about wireless.
Old April 16th, 2011, 07:50 AM   #9
Jim, I suspect the jaggies you are referring to are interlace artifacts. HD link which is part Cineform NEO HD does a great job of deinterlacing._
Old April 16th, 2011, 09:14 AM   #10
Thanks Kevin, I suspected that. I will try your suggestion later today. I can't find any information about the audio recording in the GH2. Does anyone know where I can find more info?
Old April 18th, 2011, 11:54 AM   #11
If you don't get satisfactory results lowering the receiver output, a quick/cheap/dirty method is to purchase an in-line headphone volume attenuator (Radio Shack sells these on the cheap). They are 1/8" stereo input/output...so I'm not sure if it's compatible with the GH2.
Oren Arieli is offline   Reply With Quote
Old April 18th, 2011, 12:01 PM   #12
Thanks, -30db out of the wireless receiver did the trick. I think I will pick up a couple of the Radio Shack Attenuators. It would be nice to keep the wireless receiver to the -12db setting that I use on my other cameras.
