Light Craft 52mm Fader ND Mark II Filter, any thoughts? at DVinfo.net
Old February 27th, 2011, 09:10 PM   #1
I'm looking to get an ND filter for when my Voigtlander 25mm shows up. Anyone have any experience with this one? Any other recommendations?
http://www.bhphotovideo.com/c/product/754992-REG/Light_Craft_415_52mm_Fader_ND_Mark.html
Patrick Janka is offline   Reply With Quote
Old February 28th, 2011, 07:53 AM   #2
Re: Light Craft 52mm Fader ND Mark II Filter, any thoughts?
Check out Genus brand also - they work well.
But why get the 52mm? This will not fit most other lenses then you need 2 or 3 more ND faders.
I use a 77mm ND and stop down rings to fit smaller lens sizes down to 52mm.
Jon Braeley is offline   Reply With Quote
Old February 28th, 2011, 08:59 AM   #3
That would make sense if I bought more lenses. Right now I have the stock 14-42mm. I don't plan on using ND on it because the lowest aperture setting is f/3.5, so it's not like I can really preserve a shallow depth of field on it. As far as the 25mm, its 35mm equivalent is 50mm. Then if I switch on the ETC mode that effectively gives me 130mm. Two great lenses/focal lengths for the price of one. I'm not sure what other lenses, if any I would want. If I get a wide angle lens I wouldn't be looking for shallow dof.
The only 77-52 step down ring I found on B&H is this: http://www.bhphotovideo.com/c/product/664893-REG/Novoflex_REDUZIERRNG_52_77_77_52mm_Step_Down_Ring_for.html
So the 52mm Lightcraft (or Genus) is $72, and the 77mm Genus + Step down is $135 + $58 = $193. Doesn't seem to make sense to go that route, unless I'm missing something. Thanks for bearing with me while I work this out.
Old February 28th, 2011, 01:47 PM   #4
That is not a step down ring.
You can pick up all sizes of step down and step up adapters from ebay for about $5 each. They are indespensable unless you want to buy a set of filters for each lens - not just ND, but UV, polarizers etc.
By the way ND filters are not used just to shorten the DOF. Most lenses have a sweet spot where they perform best (sharpness, abberations) and that is anywhere from F5.6 to F11.... whatever.
