Neutral Density Filters, at DVinfo.net
Old February 13th, 2011, 10:14 PM   #1
I would appreciate suggestions for a neutral density for the GH2.
Jim Snow is offline   Reply With Quote
Old February 14th, 2011, 01:53 PM   #2
Buy the FADER ND filter for your lenses. Variable ND from 1 - 8 stops of light reduction.
Fader Filters vs Traditional ND Filters Vincent Laforet’s Blog
Guy McLoughlin is offline   Reply With Quote
Old February 24th, 2011, 10:02 AM   #3
Re: Neutral Density Filters,
Jim, Guy, what's the disadvantage to shooting without a ND? For outdoor bridal party video shots, establishing shots of venues, etc, and street scenes what should I expect to encounter if I were not to have one?
Old February 24th, 2011, 10:53 AM   #4
Neutral density filter are very useful in bright light, primarily outdoors on sunny days. They limit the light so that shutter speed and aperture can be set to less extreme values. I like to keep shutter speed at 1/60th because a small amount of motion blur makes video smoother. Without a neutral density filter, it may be necessary to use much faster shutter speeds which give a 'strobey' look to video. With aperture, most lenses are at their sharpest in the center range of aperture. The 'sweet spot' is usually f 5.6 or f8 with a shutter speed of 1/60th.
I just bought this one for my GH2 http://bit.ly/eCTt08
Old February 24th, 2011, 10:59 AM   #5
Jim, your choice looks to be a very good one. I'm putting it on my "to buy" list. Thanks so much for the recommendation, oh and thanks for the detailed explanation about the sweet spot for the aperture.
Old February 24th, 2011, 11:24 AM   #6
I have found them extremely useful for shooting indoors and outdoors to achieve a very shallow DOF also.
Jim Forrest is offline   Reply With Quote
Old February 24th, 2011, 01:33 PM   #7
The main idea is to be able to shoot with your lens wide-open in bright light conditions to achieve the shallow DOF look. If you have to stop down the iris on your lens, then the shallow DOF effect disappears.
Old February 26th, 2011, 11:11 AM   #8
Thanks, Guy, for the additional explanation. Between you and Jim it all makes sense.
