What is the Lens Thread size for Lumix Lenses? Is it always 52mm? at DVinfo.net
Old January 21st, 2011, 11:13 AM   #1
If i want to add a Neutral Density filter to my lenses for GH2 what is the thread size? Is it 52mm on all Panasonic Lumix Lenses or does it vary?
Tyson X
Tyson Persall is offline   Reply With Quote
Old January 21st, 2011, 12:24 PM   #2
It varies;
46mm
14mm/f2.5 and 20mm/f1.7
52mm
14-42mm/f3.5-5.6, 14-45mm/f3.5-5.6 and 45-200mm/f4.0-5.6
62mm
14-140mm/f4.0-5.8
67mm
100-300mm/f4.0-5.6
Dave Eaton is offline   Reply With Quote
Old January 21st, 2011, 03:35 PM   #3
An option is to buy filters the size of your max. lens and then get step-up rings for your other lenses so you can use the same filters on them, too.
BTW, Polaroid is making a variable ND filter at a very reasonable price. Seen it on Amazon for $30-40. I don't have one so I can't tell you if there's a color cast or not.
Old January 23rd, 2011, 08:29 AM   #4
I just bought the Cokin system. The P-size works for my Panasonic GH2 lenses and my Pentax lenses. You need to buy step-up adapters and all, but you just have to buy the filters once. Cokin also has hoods you can add and a matte box, but they are notoriously hard to find and reviews have been mixed.
Note, someone on the internets has noted that the Panny 20 F1.7 retracts ever so slightly when you turn the camera off, so if you have a step-up ring or other adapter flush mounted it may interfere with this retraction. Here's the link:
Micro 4/3rds Photography: Home made stand off ring
john m flores, yet another still photographer getting into video
What Blog is This?
John Flores is offline   Reply With Quote
Old January 23rd, 2011, 06:03 PM   #5
Thank you all, very helpful.
Tyson X
