Which Software for Transcoding?
Hi,
I usually transcode my GH1 Footage in Toast but most of the time the Audio is not synced and about one Third of the Footage gives me a -50 Error and doesnt get converted.. Whatever this means.. So which Software would you all recommend.. Running on a Mac.. And maybe Freeware if possible.. Thanks in Advance.. oh.. and should i only Backup the Mts Files or should i save the whole Filestructure..? |
Do you own Final Cut Studio 3? That's the method I'd recommend as it's the most proper way. 'Log and Transfer' and select the PRIVATE folder, and voila, encode. It's quick too!
I used Toast as well, but it'd have problems with some files and the audio would be off, as you mentioned. You can use iMovie if you really want to, but I'd advice against.. in my experience, it doesn't see anything past 30fps (so if you shoot 60P, it'll output 30P). Good luck. |
#3 | |
I only keep my transcoded/pulldown removed footage, and delete everything else including the GH1 native files. I tried Voltaic (not free), and JES deinterlacer (free). They work, but they crash, and I have given up on them.
www.holyzoo.com |
I posted a simple (and nearly foolproof) tutorial on how to get GH1 1920x1080 images into FCP and remove pulldown here:
Hot Rod Cameras Panasonic GH1 AVCHD – 1920×1080 23.98p Compressor Workflow (pulldown removal) – Cost = FREE, if you have FCP I. Illya Friedman Hot Rod Cameras Hot Rod Cameras |
#5 |
Hi,
Thanks very much for the Info.. I own a very old Version of Final Cut.. But actually wanted to update for a long time.. Now seems to be right enough.. cheers, phil |
