Here it is the new Panasonic GH1 - Page 2 at DVinfo.net
Old March 4th, 2009, 07:08 PM   #16
For me the most important point is FullHD 24fps and shallow DOF. I've seen DOF tests from 1" sensors and they were more than ok to me. This sensor is even larger so if you put together everything:
- Sensor size a little smaller than a s35mm negative.
- FullHD recording.
- 24P.
- Full manual controls.
You have the closest to a really low cost digital cinema camera so far. That is hoping it's price is somewhere between a Nikon D90 and a Canon 5DMKII or (we can dream) even less.
Of course we'll have to see the rolling shutter in motion, it'll probably use the row skipping thing, so we can expect some artifacts and aliased borders and we still don't know if the compression will be too noticeable.
But this is looking really good...
Jose A. Garcia - Freelance camera operator, web designer and VFX artist - http://www.sinproblema.net/
Jose A. Garcia is offline   Reply With Quote
Old March 4th, 2009, 08:11 PM   #17
MPS Digital Studios
Weren't there a lot of problems with the video from these cameras when you started panning? I thought Jannard from RED posted video from one that wobbled.
heath
My Final Cut Pro X blog
Old March 4th, 2009, 10:39 PM   #18
Here’s are a couple of videos of it:
YouTube - PMA 2009: Panasonic Lumix GH1
YouTube - PMA: Hands-on with the Panasonic Lumix GH1
Paulo Teixeira is offline   Reply With Quote
Old March 4th, 2009, 11:15 PM   #19
Here is a couple of things to consider. The lens looks to be dark- F4-5.6. There is a wide (14-28mm), but also quite dark. So I don't know about the sharpness of the picture over all. Most of good lenses would have 2.8 or 1.8 aperture, 4 or 5.6 are just amateur grade only.
BTW- what would be an image difference between motion jpeg and AVCHD? Particularly with moving objects or panning?
Robert Rogoz is offline   Reply With Quote
Old March 4th, 2009, 11:38 PM   #20
Theirs also going to be a 20mm lens that’s either f1.7 or f1.4. The only problem is that it may get released around 3 months after the GH1, but then again, you can get yourself a few adapters if you want fast lenses right away.
AVCHD is significantly better than M-JPEG at the same bit rates. It just takes a bit more horsepower to edit it.
Old March 5th, 2009, 12:10 AM   #21
Let's say I have a nice set of Nikon lenses- what adapter would I have to use?
Old March 5th, 2009, 01:07 AM   #22
There may not be one yet, although if there isn't it probably won't take long. I believe there is a significant magnification factor when using full frame lenses. Anyone know offhand what it is? 2x?
Old March 5th, 2009, 01:53 AM   #23
Yes. Exactly 2x.
There's an advantage to using a less than FF35 sensor. You can crank your FF35 lenses open all the way, and not suffer any light falloff or softness in the corners, because they get cropped.
If I were to get the GH1, I'd probably get all 35mm glass, plus one MFT 12mm prime to cover the wide end of things.
Jon Fairhurst
Old March 5th, 2009, 02:37 AM   #24
Here’s some of them:
Panasonic Lumix G1 Lens Adapters
Old March 5th, 2009, 04:50 AM   #25
I'm also interested in the downscale method/quality. The integrated nature of the live view from these EVF cameras may provide a better basis for the video, compared to how live view is implemented in traditional DSLRs. Look forward to finding out what's what with this camera and the Samsung NX series later this year. Oh, that camera doesn't have an articulated LCD -- damn, there's always something...
John Wyatt is offline   Reply With Quote
Old March 5th, 2009, 04:55 AM   #26
It seems like a huge step has been taken. The guy was quickly moving the camera while shooting and I couldn't really see any rolling shutter artifacts. At least as noticeable as in a Canon 5D or a Nikon D90.
Of course the camera used to record the clip was a bit far from the Lumix lcd and he was probably using the 720p60 mode so we'll have to wait and watch an actual video recorded at 1080p24.
Just a question. If you use EOS EF-S or Nikon DX lenses you'd get a smaller magnification factor wouldn't you?
Old March 5th, 2009, 08:07 AM   #27
MPS Digital Studios
This is one of the 4/3 cameras, so I don't know if Nikon or Canon lenses (etc.) would work...
heath
Old March 5th, 2009, 09:38 AM   #28
No, it would be the same 2x, but it would be an advantage in that they are generally wider for your dollar to help balance out the price/range.
Old March 5th, 2009, 12:03 PM   #29
Don't think of the 35mm equivalent focal length . For example the canon kit lens is 18-55mm. So in m4/3 terms, the 35mm equivalent would be 36-110 . Yet I haven't seen any ef-s adapters for m4/3 . There are FD adapters however . Please correct me if I'm wrong. Start looking at the forums for more sources , but here's one for adapters
japan exposures | films and more (formerly Megaperls Japan Webshop)
they also sell a Leica M /m4/3 which , I believe allows you to use the Voigtlander lenses , which are excellent for their price .
Kurth Bousman is offline   Reply With Quote
Old March 5th, 2009, 03:05 PM   #30
More lens adapters from Here.
http://http//www.cameraquest.com/adapt_olyE1.htm
Ian G. Thompson is offline   Reply
