Using FZ2500 with Atomos Ninja Star at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX LX / FZ / ZS Series
4K and AVCHD via compact point & shoot "bridge" cameras.
Old January 27th, 2017, 02:26 PM   #1
I am having trouble getting the Ninja Star to recognize the HDMI output. The HDMI works with an external monitor. Any help would be appreciated.
Frank Grygier is offline   Reply With Quote
Old January 27th, 2017, 06:30 PM   #2
Re: Using FZ2500 with Atomos Ninja Star
Atomos recorders only recognise AVCHD video ...I had the same issue on the FZ1000 ..I usually shoot in MP4 and it wouldn't recognise my input but if you use AVCHD mode on the camera it will see the HDMI output ... One word of caution though ...I was also using the HDMI passthough to feed a LiveStream Encoder and the encoder didn't like the AVCHD HDMI for some reason.
In your case simply switch to AVCHD mode on the camera and it will record fine.
Old January 27th, 2017, 07:05 PM   #3
Thank you Chris,
I will give it a try.
Old January 27th, 2017, 08:56 PM   #4
If the HDMI is outputting progressive 24p or 60p the recorders can have issues as well. On my A7S I need to output good old vanilla 60i HDMI. The Atomos recorder will take care of the pulldown removal.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old January 28th, 2017, 08:14 AM   #5
Thanks for the help.
I am trying to do the 4K down convert to the Atomos Ninja Star. It works fine with my GH4.
Old January 30th, 2017, 02:42 AM   #6
I have no problem for the Ninja Star to recognize my video. It is set on MOV, 25P 200Mb. I am in PAL land, so that works.
I have a problem getting the Ninja Star to automatically start/stop. Did anyone get that to work?
Wim van der Meeren is offline   Reply
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX LX / FZ / ZS Series
