Timecode Sync/HC-X2000 and Atomos
Is it possible to send time code from the Panasonic HC-X2000 to a Atomos Shogun Inferno? Basically we're capturing breakout rooms. We're backing up the audio we record from the camera to the Atomos. At the same time we'll record the powerpoints on the Atomos.
I'm not the most technically savvy person...but I remember that in the past we were able to slave the timecode between a DVX200 and a Pix Recorder. The client is providing the cameras. Any help is appreciated. The more specific the better! |
Re: Timecode Sync/HC-X2000 and Atomos
If you can send the audio to both then you can sync them in editing software. Timecode not usually used for what you describe. If you have the equipment and knowledge then there's no harm. Otherwise I'd avoid it.
