HC-X1 removing hood to add filter? at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
4K and HD consumer camcorders with professional interest.
Old March 26th, 2020, 12:09 PM   #1
Hi.
Just purchased an HC-X1. I have a protective UV filter to put in front of the lens but can't yet figure out how you remove the lens hood to be able to do this. Can find nothing in the manual or on-line. Can anyone tell me how to do this?
John
John Whiteway is offline   Reply With Quote
Old March 26th, 2020, 01:19 PM   #2
Re: HC-X1 removing hood to add filter?
Press the little button and turn.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old March 26th, 2020, 01:36 PM   #3
Thanks. I actually came across the info in tthe manual shortly after I posted. Guess I should read more carefully. Now to learn the camera.
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
