Question about HC VX870 at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
4K and HD consumer camcorders with professional interest.
Old September 17th, 2015, 06:40 PM   #1
I just bought a little 870 to see what I could do in 4K. It is nice that the unit has a manual iris, but is it really an iris? The settings seem to change the exposure by increasing the gain (in dB, that's gain, not exposure). Is there a way to adjust the exposure while keeping the gain at a sensible 0 dB?
Steve Siegel is offline   Reply With Quote
Old September 20th, 2015, 01:00 AM   #2
Re: Question about HC VX870
In page 67, the user manual says : "When the iris value is adjusted to brighter than OPEN, it changes to the gain value"
It sounds like Gain is at 0db until you go beyond full open Iris value...
Emmanuel Asset is offline   Reply With Quote
Old February 5th, 2016, 10:29 AM   #3
When changing the iris value, the displayed iris/gain value is changed only for every other step up or down, while the actual brightness of the picture changes for every step up or down.
So, I guess there are intermediate iris and/or gain values that are used but not displayed.
And I have no clue which one of each step in a "pair" actually matches the displayed value.
The question is: when do I actually have iris fully OPEN and NO gain ? When does gain actually kick in ?
If I increase brightness from some larger iris value step by step until OPEN/0dB is displayed, I can go one step further (brighter) and still see OPEN/0dB...is the latter now the real 0dB or did I just start adding 1.5 dB gain ???? Or was the "first" OPEN/0dB more "something between f 1.8 and OPEN=F2.0 / 0 dB" and the second one really OPEN/0dB ?
Benoit Matthys is offline   Reply
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
