X900/920 EVF Compared to TM700 at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
4K and HD consumer camcorders with professional interest.
Old June 26th, 2013, 06:12 PM   #1
X900/920 EVF Compared to TM700?
I'm looking to upgrade my aging TM700, but would like something with a better EVF. The TM700 EVF is barely usable for framing. For those who've already upgraded, have you found the X900/920 EVF an improvement?
Many Thanks,
Dan
Dan Carter: HDC-TM700, DMC-GH2 and DMC-GH3, Sony RX100II and RX10, Final Cut Pro X
http://www.vimeo.com/user582748
Dan Carter is offline   Reply With Quote
Old July 10th, 2013, 11:27 PM   #2
Re: X900/920 EVF Compared to TM700
Found a bit of info on these EVFs:
TM700: 123K
X920: 263K
Technically, the X920 should be an improvement.
Old July 11th, 2013, 01:18 PM   #3
Hi Dan, I just bought the X-920 and I have the TM700 there is a difference, the best way I can describe it is like this, the TM700 EVF is like going closer to your T.V. screen until you see the pixels that start making up the pictures, so you can see the dots (like news print) you can verify that by looking through your EVF, the X-920 you don't see the pixels it's smoother and sharper looking.
My Stock Video Blog
Linkedin
Norman Pogson is offline   Reply With Quote
Old July 11th, 2013, 05:29 PM   #4
Thank you for the review Norman. This is helpful.
I hope your new X920 is a success...
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
