Panasonic XC-920 Pricing at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
4K and HD consumer camcorders with professional interest.
Old January 9th, 2013, 10:58 PM   #1
From B&H posted 1/9/13:
http://www.bhphotovideo.com/c/product/910265-REG/panasonic_hc_x920k_hc_x920_3mos_ultrafine_full.html
Good luck, Panasonic at this price.
Walt Stagner is offline   Reply With Quote
Old January 10th, 2013, 03:27 AM   #2
Re: Panasonic XC-920 Pricing
They'll probably sell more than Sony will sell of the $1599 HDR-PJ790V :)
Bill Bruner is offline   Reply With Quote
Old January 10th, 2013, 07:29 AM   #3
Ha, Ha....color me sprised if the BH price isn't $999 when shipped.
Even at that price there isn't enough there, there. It makes the current models (and the tm700, tm900) look like steals!
3d is D.O.A.
Old January 10th, 2013, 09:14 AM   #4
I think the X900 was around $1199 or so when it came out and saw it as low a $599 during Black Friday. I hope by the end of this year the XC-920 might get down that low at which it will be a great buy.
www.speedandmotion.com
Duane Steiner is offline   Reply With Quote
Old January 10th, 2013, 09:41 AM   #5
And the TM900 the year before that started out about $1,100 (from memory) and ended up pretty cheap when it was superceded.
As always, for those that don't need (or yearn for) the latest tech there are some amazing bargins to be had on what are still very capable "last year's model" cameras.
However, if low light performance is something you need, I'd definitely wait for trusted/critical reviews of the XC-920 to see if Panny's claims stack up before deciding.
Old January 10th, 2013, 09:41 AM   #6
Panasonic HC-X920 3MOS Ultrafine Full HD Camcorder HC-X920K B&H
LOL, the add also says
Three 1/2" 3MOS Sensors with BSI
So, if that were true, then 1198.00 would be a great price. On the other hand probably both number are subject to revision pretty soon.
Eric Olson is offline   Reply With Quote
Old January 10th, 2013, 11:22 AM   #7
You are correct.
Try this link:
http://panasonic.net/avc/camcorder/hd/x920/
Old January 12th, 2013, 11:30 AM   #8
My calculations are below:
Code:
              Actual       35mm Equivalent   Advertized      Actual
            Focal Length     Focal Length    Sensor Size   Sensor Size
HD-X900M    2.84-34.1         29.8-357.7       1/4.1"    3.43mm x 2.29mm
HC-X920M    2.84-34.1         33.1-397.1       1/2.3"    3.09mm x 2.06mm
The sensor is actually 10% smaller in the X920. This is important to know when calculating depth of field and aperture diffraction limits.
Old January 12th, 2013, 01:24 PM   #9
According to these specs, the 35mm equivalent for the X920 is 29.8 - 399.2 mm.
http://panasonic.net/avc/camcorder/h...fications.html
While for the X900, it's 29.8 - 368.8 mm
The specs for the "Motion Image" is what should be used, not the specs for the 3:2 still image although the specs for the 16:9 image is obviously the same as the Motion Image.
Paulo Teixeira is offline   Reply With Quote
Old January 12th, 2013, 02:32 PM   #10
HC-X920/HC-X920M/HC-X910 | HD Camcorder | Panasonic Global
HC-X900/HC-X900M/HC-X800 | HD Camcorder | Panasonic Global
I would have used those numbers, except that 399.2 divided by 29.9 would then imply the X920 has a 13.4x zoom and 368.8 divided by 29.8 would imply the X900 has a 12.4x zoom. However it is known both cameras actually have a 12x zoom. Therefore, I used the 35mm equivalent focal lengths for 2:3 still images which were at least consistent with the zoom range of the lens. Since a standard 35mm frame is 36mm x 24mm, then 35mm equivalence makes the most sense for 2:3 still images anyway.
Last edited by Eric Olson; January 12th, 2013 at 04:14 PM. Reason: 12x zoom not 10x zoom (thanks Paulo, see below).
Old January 12th, 2013, 02:51 PM   #11
Panasonic do claim 12x for both cameras though.
Old March 15th, 2013, 10:04 PM   #12
Code:
I think the size difference is because Panasonic are using the same sensor block that goes into the AG-AC90, which has Back Side Illuminated (BSI) imaging chips.
Steve Struthers is offline   Reply
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
