TM-700 Display question at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
4K and HD consumer camcorders with professional interest.
Old May 4th, 2012, 09:57 AM   #1
I'm trying to display out from the camera to a monitor without any of the camera info. I have the display turned off and everything is fine, EXCEPT the icon for the OIS (the little hand) is being displayed on the monitor. The only way to get rid of it is turn off the OIS.
I have also noticed that if I'm in iA mode - that symbol is also displayed. I shoot in manual so that is not an issue. Is there another way to be able to use the OIS and not have the icon show on the monitor?
Herm Stork is offline   Reply With Quote
Old May 4th, 2012, 03:49 PM   #2
Re: TM-700 Display question
I am not familiar with the TM 700 but in the case of the TM 900 there is a button on the IR remote marked "display" that can be used to scroll through the available options.
Old May 4th, 2012, 04:21 PM   #3
That did it - THANKS!
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
