The Panasonic TM900 Users Thread - Page 56 at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
4K and HD consumer camcorders with professional interest.
Old January 7th, 2013, 01:09 PM   #826
Re: The Panasonic TM900 Users Thread
Just a note, I'm not about to lock this thread or anything, but please make sure that any further additions to this discussion are actually about the TM900 itself (now long since discontinued). If I can find the time, I'll try to peel out all of the X900 posts and put them into their own topic, and perhaps the time is right for a forum dedicated to these little cams. For now though, please, if it ain't about the old TM900, then choose another thread or start a new one -- thanks a bunch for understanding!
Old January 8th, 2013, 04:35 PM   #827
Hey, when you guys are shooting with the TM900 (and probably the other newer models...) and you have locked down several variables in manual, say white balance and shutter, and then you want to return one or more variables back to automatic - what's the best way you've found to do that and interupt shooting the least?
Roger Shealy is offline   Reply With Quote
Old January 14th, 2013, 09:28 AM   #828
Can I take issue with Chris. Since the XM 900 and, from first reports at CES, the XM 920, have fundamentally the same features, I would endorse keeping all this invaluable information on the practical usage of these great camcorders together on the same thread. Although the Panasonic AG-AC90 uses the same chip configuration and processing, I would not add it to this thread, as the control and operation of this camcorder are quite different.
Incidentally, I recently did a professional shoot using a Canon XF305 for the close-ups and my TM 900 as a cover wide shot. Other than a slight colour tweak in post, the cameras matched very well even though one cost ten times as much as the other.
Guy Caplin is offline   Reply With Quote
Old January 14th, 2013, 09:40 AM   #829
I too pair my tiny SD900 with my Sony NX5 on professional shoots and often the 900 outperforms the seven times more expensive Sony. To be fair the 900 shoots native 1920x1080 whereas the NX5 is shooting about half that in its quest to get better low-light performance, and generally I'm handholding the NX5 with megaOIS turned on, losing me even more resolution.
tom.
Old January 15th, 2013, 06:51 AM   #830
I have also. If it is well lit, it's not a bad b cam.
Al Bergstein is offline   Reply With Quote
Old January 31st, 2013, 04:55 AM   #831
We use the TM900 with 7D all the time. Sometimes the hues are a little different and hard to match perfectly, but they work together great.
Old February 9th, 2013, 10:30 PM   #832
Trimming long MTS clips before storage: -
I have an interest in natural history and use an EX3 and/or a Panasonic TM 900 to obtain my material. As my subject matter can be unpredictable my takes are often very long and need trimming before being added to a library of sorts. Sony provide ‘Content Browser’ that makes selecting desired sections from a long EX3 take very quick and very easy.
Is there a similar program with which I could do the same for my Panasonics MTS files?
Old February 10th, 2013, 01:24 PM   #833
The HD Writer software which came with your TM900 can do this.
You do need all the original files that the TM900 created though in order for HD Writer to deal with it.
It is very straightforward to trim off the start and the end - see the help files. If you want to make multiple cuts part way through and have each as a separate file I think you will have to run it through the process several times though.
It is all non-destructive, does not involve rendering, and is quick.
Pete
Peter Riding is offline   Reply With Quote
Old February 10th, 2013, 04:34 PM   #834
Thanks Pete,
Sounds good but when I read up on HD writerI got the impression it was Windows based only and I am on an iMac. I will investigate using HD writer with Bootcamp.
Old February 15th, 2013, 05:59 AM   #835
AlastaIr you might find that the internal trimming function in the camcorder itself would suit your purpose. The function is not particularly well documented in the manual but I have found it intuitively easy to use. I have been cutting off long leads into action by dividing the original clip into two separate clips and then deleting the unwanted section. This saves memory on the recording card and cuts copying time into the editing system.
Old February 16th, 2013, 01:47 AM   #836
Thanks Guy,
I have used the camera's edit function to eliminate unwanted material and it is a handy feature to have. However in a long natural project I tend to accumulate a lot of similar material and it is not easy to pick the most important clips on the small screen.
I had a look at HDWriter but did not like idea of its apparent inability to import a clip more than once. At the moment I am using Edius for trim and sub-clips and it looking promising.
Old March 9th, 2013, 04:24 PM   #837
Hi there, i'm using TM900 for 2 years and i'm very happy with this camera. Made hundreds of videos. The only problem is - the microphone. Need help from pro's. Which mic system should i use to shot 3-4 people in studio? Sunheiser does not fit TM 900.
Fariz Abasov is offline   Reply With Quote
Old March 9th, 2013, 05:06 PM   #838
If you want to use on camera omni microphone the Audio-Technica Pro-24CM is a good choice.
Adrian
from Super 8 & film splicer to TM900/X920 & Vegas 12
http://vimeo.com/user10818624/videos/
Adrian Lepki is offline   Reply With Quote
Old March 9th, 2013, 06:38 PM   #839
Well i need to record a conversation between 3 or 4 people with high quality sound. I need separate mics.
Old March 9th, 2013, 07:08 PM   #840
In this case you'll need a mixer (i.e. Sound Device 302) and wired lavalier mics. If the conversation takes place around a table it is possible to use 1 or 2 boundary mics.
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
