Some DVX100 Questions at DVinfo.net
Old March 25th, 2003, 08:14 AM   #1
As it stands right now, I’m looking to shoot with the PAL DVX100E, unless something better comes out in late 2003. However, there is one problem, I need true 16:9. So my question is this, just how bad is the optical softening on the Anamorphic adapters? I know that the zoom range is limited with Anamorphic adapters, and that focusing is tricky with them, but is the optical softening of the image (due to the extra glass) really that bad? Also, is there anyway to remotely control focus with the DVX100 while using something like a jib?
Glenn Gipson is offline   Reply With Quote
Old March 25th, 2003, 08:55 AM   #2
Re: focus control, remote: not yet, but soon. Keep an eye on www.varizoom.com.
Old March 27th, 2003, 12:19 PM   #3
Exactly how are they going to pull off remote focus for the DVX-100? I seen the pin outs for the remote jack on another website and there doesn't appear to be any provision for focus.
Is this going to be some type of mechanical/manual rig?
Carl
Carl Slawinski is offline   Reply With Quote
Old March 31st, 2003, 08:44 AM   #4
A rep from VariZoom posted this in the DV Industry News section:
4. VZ-DVXFF This our new Follow focus control for the DVX100 control. It has 4 positions you can mark in and either manually dial to pre programmed positions or you can push a button and go there automatically.
