HELP!How do CC from inside setting- outside setting White Balance on DVX100a at DVinfo.net
Old October 1st, 2006, 02:42 AM   #1
Sorry if im crossing i don't think i am from the posts i've seen. My problem is simple. During a wedding shoot my partner changed his white balance from the outside setting to the inside (we were shooting out side) looking for how to match the shoots....
Jamon Lewis is offline   Reply With Quote
Old October 1st, 2006, 10:38 AM   #2
Images: 1
It depends on which editor you're using, but a 3 point color corrector will generally match the shots. You apply the color correction by sampling a known black, white, and gray from the correctly WB'd clip, and apply the filter to the incorrectly balanced clip.
-gb-
Old October 1st, 2006, 05:29 PM   #3
hey greg thanks for the response and the info i'll try it and let u know how it works (not that it won't just that i don't understand from just the instuctions but i think it will make since at some point of me actually do'n it) Thanks again
Old October 1st, 2006, 05:31 PM   #4
Images: 1
What editor are you using? We might need to move your question over to the relevant NLE forum as this really isn't a camera issue.
-gb-
Old October 1st, 2006, 05:31 PM   #5
btw im use'n fcp 5.1.2 with a mac pro the wedding was shot wit 2 dvx 100a and a hd100 u, thanks again
Old October 1st, 2006, 05:33 PM   #6
ok sorry again as far as posting my issue in the right spot. i looked untill i nearly pulled my hair out and finally just had to do something :(
