Can someone help me with the settings of these shots? at DVinfo.net
Old August 21st, 2006, 08:53 AM   #1
Hello Folks,
I just need your help if you can, to try to help me out with the settings of these next images... Bascially how can I establish shots like this including lighting and so on.. please... Thank you..
Really would appreciate your help folks!!! thanks
1st pic is like "Greenish"
2nd pic im not to sure how to describe it, has light but the black colors are very strong
3rd pic has alot of light
4th pic is green and dark
PumaTalk.com - Talk about your PUMA kicks & PUMA gear.
Joey Dee is offline   Reply With Quote
Old September 6th, 2006, 07:58 AM   #2
Did you set your white balance?
Jon
Jonathan Shannon is offline   Reply With Quote
Old October 31st, 2006, 06:54 PM   #3
I agree, make sure to white balance whenever you change the lighting conditions. Also, more specific to your shots:
1. The green could be due to flourescent bulbs. Are you lighting your sets? White balancing?
2. May not be lit enough, or the nd filter is on, or the master pedal is too low, or iris is closed.
3. Your iris could be open with too much light in the shot. Try an nd filter, or closing the iris a bit.
4. Again, white balance, flourescent light, not lit enough, nd filter on, closed iris.
Make sure you light for the subject, the auto iris feature can sometimes make a shot too dark if, for example, there is an window with a light coming in, the rest of the room will look dark, including your subject.
Dino Santoro is offline   Reply With Quote
Old November 7th, 2006, 06:31 AM   #4
Originally Posted by Joey Dee
Hello Folks,
1st pic... hmm perhaps a white balance on a purple card... the rest in post.
2nd pic... put your master pedestal at - 5 and go from there.
3rd pic.. ??????
4th pic... one and two?
Seriously though if you can provide images to see what your talking about it would be much easier to help.
Noel Evans is offline   Reply
