Optimal DVX-100a settings at DVinfo.net
Old July 17th, 2006, 02:02 PM   #1
When recording indoor sports events under lights that are not well-diffused I have run into the problem of hot spots of excessive lighting intermixed with darker areas. Are there gamma or other adjustments that will help reduce the overexposure in the hot areas ?
Mark Donnell is offline   Reply With Quote
Old July 18th, 2006, 09:49 AM   #2
Send a PM to Barry Green. He's the DVX guru.
Interesting, if true. And interesting anyway.
Hugh DiMauro is offline   Reply With Quote
Old July 18th, 2006, 03:50 PM   #3
Barry Wan Kenobi
For maximum latitude you'd want to use cinelike-D gamma, and keep your zebras on 105% and make sure nothing clips out. You can also stretch your shadows a bit by raising the master pedestal up a notch or two.
Barry Green is offline   Reply
