Can I use a wireless and shotgun at same time at DVinfo.net
Old June 24th, 2006, 01:17 PM   #1
Just bought a DVC 30 with the XLR. I have a shotgun mic. I would like to tape a friends wedding. If I use a wireless mic on the groom, should I also use a shotgun mic on the camera. Will the sound be OK or will 2 mics screw up the sound.
Tim
Tim Richards is offline   Reply With Quote
Old June 24th, 2006, 01:21 PM   #2
Jubal 28
Tim
In most NLEs, you can separate the audio tracks, so you'll be OK.
David Jimerson is offline   Reply With Quote
Old July 6th, 2006, 01:15 AM   #3
I routinely shoot with this sort of set-up for weddings.
You just have to make sure you have the correct switch settings on the XLR. ie the CH SELECT switch on INPUT 2 should be set to the CH2 position.
Wayne
Wayne
If there's no Internet in Heaven, I'm not going!
Wayne Starick is offline   Reply
