Thread Tools
Search this Thread
DVX Color Calibration
Hi,
I just purchased the DVX100B. I am wondering if any DVX users have been following Paolo Ciccone's threads (here and here) and web site on the color calibration he has done using DSC Labs charts and a vectorscope? Paolo has been able to get an excellent calibration with good latitude and precise and vibrant colors. Has anyone done similar work with the DVX series? I have seen lots of scene files floating around for personal preferred looks and stylistic looks, but nothing in terms of a highly accurate calibration. Thanks, Josh
Owner/Operator, 727 Records Co-Founder, Matter of Chance Productions Blogger, Try Avoidance |
Hrm, I'd like help as well. I just got a DVX100b used and would be more at ease if I knew it was calibrated correctly.
I personally use warm card. http://www.warmcards.com/. The manufacturer claims that the white side of the card is calibrated to 100 RE. Along with the vectorscope, if you stay below the 100 mark you will not clip your highlights. As for the color calibration, I have DV Rack and again the manufacturer claims that the color bar is accurate since the color bars are not compressed like the one used on DVXs.
So with these combinations, in my opinion, the colors are TECHNICALLy correct. The other "expensive" option is to get an external NTSC monitor and a decent color generator to calibrate the DVX before any shoot. |
My question is actually a little different. White balance is not the issue. We know that pretty much every camera has a different look, even when shooting the same scene with the same white balance. I'm wondering if anyone has scoped the DVX against a good test card and found how to calibrate the MP, matrix, gamma, chroma level, chroma phase, etc. to get technically accurate color.
