Wide Angle Lenses - Page 5 at DVinfo.net
Old February 24th, 2005, 12:09 PM   #61
I'm thinking about getting this as well. I had a question though, would you rather go 16:9 and lose quality, or 4:3 wi/ a wide-angle lense and keep it picture perfect?
Spike Spiegel is offline   Reply With Quote
Old February 24th, 2005, 02:28 PM   #62
16:9 vs 4:3
hi Mr Spiegel
well sir the dvc30 dose not have real 16:9 . so i use sqeeze mode whitch dose a very nice job by the way . and i almost always use the wide lens . i think it dose a good job you can zoom rite through and it stays in focus . so all and all i would say its very good . but my standards may be lower than the next guys so it is best to see for yourself . i hope this is helpful . dp
dp
Donald Pittelli is offline   Reply With Quote
Old February 28th, 2005, 09:53 AM   #63
LW-4307
Hello
I just bought the Panasonic 0.7 Wide Angle (AG-LW4307) adapter and I like that image quality comparing the on camera lens to the lens plus adaptor, is very consistent.
There is relativelly minor barel distortion on opening up fully but it is minor and predictable that an adapter like this will produce this effect.
The wide angle is of course not as radical as the .3 Century one but is like using a 28mm wide lens instead of a 45mm lens in 35mm stills photography.
Hope this comment is of use to someone looking for this kind of adapter.
Regards
Leo
Leo Salazar is offline   Reply With Quote
Old March 8th, 2005, 01:27 AM   #64
Another solution is to use a 43mm-58mm adapter, then mount a Canon WD-58H or a Century DS-65CV58 screw-in lens. Neither should vignette since your are going up in ring size. But this is just an opinion for more options, in case someone is unhappy with their 43mm Panny lens.
Want to get more from your hard-earned gear? Digital Cinema Filmmaking Course
24 hours of educational video on 16 DVDs, focused on filmmaking savvy, examples, demonstrations, and tips.
Learn Scriptwriting, Formatting, Editing, Camera Operation, Lighting, Exposure, Audio, and Directing.
Rush Hamden is offline   Reply With Quote
Old March 8th, 2005, 01:51 AM   #65
that is exactly what i just did, i just ordered a stepup from 43-58 and the Canon WD-58H, i'll post pics and results once i get it
Evan C. King is offline   Reply With Quote
Old March 10th, 2005, 09:49 PM   #66
Protection
Is it correct that the AG-LW4307 has no front filter threads?
Does everything have to be done with matte box/filter attachment?
Why would they build a lens without threads?
Dan Davis is offline   Reply With Quote
Old March 11th, 2005, 07:30 AM   #67
no front threads
Hello Dan
It is correct, no front threads...
Coming from stills photography, I have wondered why in the realm of camcorder optics no front threads seems to be quite normal...
All movements in life require some re-adjustment.... !
On all other aspects, the AG-LW4307 is great, I hardly use the camera without it.
Regards
Leo
Old March 20th, 2005, 08:03 PM   #68
Pana doees not make lens(do they)
Pana doees not make lens(do they)?
Probably leica so thats why people say its good probably is
Pana outsources for lense(also some ccd's)
Lebroz James is offline   Reply With Quote
Old January 1st, 2006, 10:54 AM   #69
Wide Angle
I need a to get a bit wider with the lense on my DVX, any recommendations or things to stay away from? Thanks
Michael Best is offline   Reply With Quote
Old January 2nd, 2006, 09:19 PM   #70
Century Optics sells good stuff. You need to figure out what exactly you want because different wide angles offer different advantages.
www.centuryoptics.com
Tim Hyten is offline   Reply With Quote
Old January 2nd, 2006, 10:07 PM   #71
Thanks for taking the time Tim
Old July 28th, 2007, 12:41 PM   #72
DVX100b Wide Angle Lense
I need to purchase a wide angle lense for my camera. Any suggestions? Its has to be fairly reasonable. I found a cheap one on ebay, has anyone used this one. I would actually want to spend a little more, but no more than $200.
http://cgi.ebay.com/72mm-Wide-Angle-...QQcmdZViewItem
Is a dvx100b lense compatible with a dvx30?
Andy Loos is offline   Reply With Quote
Old October 14th, 2007, 01:52 PM   #73
Wide Angle Confused
I need a wide angle conversion lens. My question is what is the difference between one that is zoom thru and one that is not? I can find a lens for $200 or up to $700 but need to know what I am paying for.
J.S. King is offline   Reply With Quote
Old October 14th, 2007, 03:29 PM   #74
i can hardly remember a WA lens made for video that is not zoom thru.
(but any way if you purchase such a lens, it is not to use it fully zoomed ?)
Old October 14th, 2007, 06:07 PM   #75
Zoom through means you can use the full zoom range. Probably without having to fiddle with the focus.
Non-zoom through...won't. Or, at least, not fully.
For instance, the Century .6 will only let me zoom to about 70 on the DVX. After that, forget about focusing the thing at all.
Daniel J. Wojcik is offline   Reply
