dvx200 low light at DVinfo.net
Old December 4th, 2016, 08:06 PM   #1
dvx200 low light
I was looking into this camera or the ux90 for second wide shot for stage performance. I saw this video of rock band in low light but I see a strange flickering of the lights behind the performers like you would see if you filmed a computer screen. Is this a function of large single sensor?
I read contradictory options whether dvx200 is good in low light. I understand it wouldn't be as good as a full frame such as an A7S but I'm more interested how it compares to 3 chip 1/3" camcorder?
Old December 4th, 2016, 10:06 PM   #2
Re: dvx200 low light
A DVX200 has a m4/3 sensor.
Isn't the larger sensor going to do better in low light?
Be well.
Rob
Smalltalk.Productions
Rob Katz is offline   Reply With Quote
Old December 4th, 2016, 10:19 PM   #3
Be well.
Rob
Yeah I would think but I read mixed opinions was low light performance.
Old December 5th, 2016, 05:15 AM   #4
[QUOTE=Pete Cofrancesco;1924396]I was looking into this camera or the ux90 for second wide shot for stage performance. I saw this video of rock band in low light but I see a strange flickering of the lights behind the performers like you would see if you filmed a computer screen. Is this a function of large single sensor?
QUOTE]
Pete,
this is definitely not an issue with a large sensor. It looks like a stroboscopic effect due to small differences in camera frequency and mains powering the lights, which are probably LED's or fluorescent/mercury lamps. To avoid it, you may need to run in variable frame rate and adjust the camera to have the same frequency as the mains.
Joachim
Joachim Claus is offline   Reply
