Look-Up Table from VLOG to Rec.2020 at DVinfo.net
Old October 25th, 2016, 09:48 AM   #1
For those who are interested in a LUT which converts VLOG recorded media into Rec.2020 compliant format. The LUT was created by using transfer characteristics from VLOG to Linear (CIE 1931), and then from Linear to REC.2020. The resulting 1D-LUT was then used in DaVinci Resolve to generate a 3D-LUT.
One LUT is set with 100% rnage, the other is set with white at 90%.
Regards,
Jaochim
Joachim Claus is offline   Reply
