#16 | |
Re: When to use V-Log
#17 | ||
Barry Wan Kenobi
Summing four pixels together retains the differences in shade between them. The difference between 508, 510, and 512 will be retained by the downconversion method, where it would be lost in the "bit padding" method used when recording 8-bit data into a 10-bit codec. Quote:
http://fiftv.com/Gradient/Gradient-8...nconverted.psd Download that file. It's a photoshop document with two layers. Each layer is an identically-parameter gradient created in Photoshop; one layer is native FHD at 8 bits, the other is FHD which was created by making an 8-bit UHD gradient, and downconverting it to 16-bit using bilinear. Note, I used 16-bit because Photoshop doesn't have a 10-bit option, but -- it won't matter at all, because if your theory is correct there should be no benefit whatsoever, right? So it shouldn't matter if it was done in 8-bit or 10-bit... also, I used bilinear mode; I didn't even use bicubic, which would have done much better. Of course, if you use "nearest neighbor", then there won't be hardly any improvement, so -- why do that? So just view that at 100% size, and toggle the layers on and off, you'll see the differences. Stretch it up or yank it down, manipulate it however you want, you'll see that the downconverted UHD holds up much better than the native 8-bit FHD. So there's obviously more data being stored and retained, more shades available, in the downconverted UHD. |
#18 |
The banding is smoothed out somewhat, but not by a whole lot.
And you said nearest neighbor wouldn't make any difference, and there's a lot of comments using "proper" software, so what is this proper software explicitly? After Effects? Resolve? EditReady? And which settings? |
#19 | |
Barry Wan Kenobi
Look at the gradient photos I just posted. The benefit of downconverting 8-bit UHD to 10+ bit FHD is obvious, and contributes to much less banding. |
#20 | |||
Barry Wan Kenobi
It's definitely better. And that's just using bilinear.
Here's the source 8-bit UHD gradient if you want to use it to experiment with. http://fiftv.com/Gradient/Gradient-8-bit-UHD.psd |
#21 | |
