Can I use a Sony 58mm tele lens on a DVC30... at DVinfo.net
Old September 10th, 2005, 04:28 PM   #1
using a Step Up Rings from 43mm to 58mm? Or the Step Up Rings are just for filters? I am afraid the tele lens is to heavy for the camera lens.....
Any info about will be very apreciated
Federico Prieto is offline   Reply With Quote
Old September 10th, 2005, 06:45 PM   #2
I'm sure you probably can, but you will have severe vignetting at everything but full telephoto.
Stefan Scherperel
SSE Productions
http://www.stefweb.net
Stefan Scherperel is offline   Reply With Quote
Old September 13th, 2005, 05:04 PM   #3
thanks for the info
Old October 7th, 2005, 02:51 AM   #4
I think you mean you have a camera with 43 mm filter threads and you want to use a 58 mm lens in front using step-up rings. Is this right Federico? In which case you'll be absolutely fine, and Stefan's wrong - you'll be able to use lots of the zoom before vignetting occurs. Of course the 58 mm optic will be a big and heavy lump though.
I do this all the time with my VX2000 lenses on my diminutive MX300, as shown here:
http://www.fortvir.net/gallery/tom-s...MX300_Aspheron
tom.
Old October 7th, 2005, 07:30 AM   #5
Frederico,
I use this setup on my DVC 30 and it works great.
Regards,
Mark
Old October 7th, 2005, 08:40 AM   #6
You know, I always wanted to try that lens out on my GL1, how does it do against a basic 2x telephoto?
"Babs Do or Babs Do not, there is no try." - Zack Birlew
www.BabsDoProductions.com
Zack Birlew is offline   Reply With Quote
Old October 12th, 2005, 11:08 AM   #7
thanks for the useful info
F
