which tape? at DVinfo.net
Old May 20th, 2005, 06:03 AM   #1
which tape?
hello everybody!
i have an dvx100a and i'm not quite sure
about the tape i should use.thank you for
any help!
Rolf Schwarz is offline   Reply With Quote
Old May 20th, 2005, 06:29 AM   #2
Panny Camera - panny tape. Panny PQ or MQ. I use MQ. Just don't mix brands. If you have been using another brand (especially Sony), run a cleaner tape thru your cam for 10-12 seconds before switching to Panny. Lubricants are different and can cause long term buildup on heads if you mix them. If you want more info, do a search, thsi question comes up alot in various forums.
You are either growing or dying.
Bob Costa is offline   Reply With Quote
Old May 20th, 2005, 11:30 AM   #3
I can second that.. although you should not overdo with the clening tape since it causes your heads to wear off.. Better stick to one brand!
www.mattzi.de
Mathiu Zimmermann is offline   Reply With Quote
Old May 20th, 2005, 02:07 PM   #4
i used 2 hours of tdk tape,is there any cleaning necessary?
and if so will the panasonic cleaning tape i got with the
camera be fine?thank you again for help!
