Panasonic DVX / DVC Battery topics - Page 2 at DVinfo.net
Old December 8th, 2002, 05:28 PM   #16
batteries...
They are made in Japan - as to why they are cheaper in Malaysia than Tokyo is anyones quess. The following battery fits the pana:_
For Panasonic CGR-D320/VW-VBD25
Li-ion, 7.2V. 2800mAh
$125.92 for 2 batteries
Dean Harrington is offline   Reply With Quote
Old December 9th, 2002, 07:08 PM   #17
How long does that one you posted last?
Proud Owner of the AG-DVX100 :D
David Nussbaum is offline   Reply With Quote
Old December 9th, 2002, 07:44 PM   #18
batteries
They are 2800 amps - with the LCD on and- light source if any- don't count on more than 2 and half hours. At bit longer if you don't use the LCD much.
d
Old December 24th, 2002, 11:20 AM   #19
this is what you want.
CGR-D28 Lithium-Ion Battery Pack (7.2v, 2800mAh) for Panasonic Mini DV Camcorders
www.bhphotovideo.com
i wouldnt go for third party batteries and what not. im gonna order that today.
Old December 26th, 2002, 07:04 AM   #20
Outer Circle
For what it's worth, the DVX uses the same batteries as MX3000. Buying barteries through Tim, might be cheaper. You can get Tim's e-mail here:
http://www.dvfreak.com/pana_mx5.htm
Also, Allan can get them. His e-mail is on the MX forum. He is a regular poster there.
Old January 1st, 2003, 01:59 PM   #21
If you do a search for "CGR-D28" at the B&H site, you'll also see a third party battery made by Power2000. Theirs is $15 cheaper than the official Panasonic one and higher capacity too (3600 mAH vs 2800 mAH)... I'm thinking of picking one of these up, any thoughts?
Also, while we're on the topic of batteries, check out the CGR-D54. Its the largest capacity on-camera battery available right now for the DVX100-- at 5400 mAH, it is supposedly good for up to 9 hours. Unfortunately, its only available in Japan. If anyone knows how to get their hands on one of these for a reasonable price, let me know.
Here's a pic:
http://www.panasonic.co.jp/bsd/sales_o/02products/products/ag-dvx100/dvx100_op.html
Joe Kowalski is offline   Reply With Quote
Old January 1st, 2003, 03:00 PM   #22
CGR-D54...
You might ask Tim (Frank's suggestion) about them. I've seen them at Bic Camera. They are a bit bulky by the look of them. They are priced at about 18,000 yen. That would be about $150.
Old January 5th, 2003, 01:11 PM   #23
Thanks guys for the info. Does Panasonic (or any other manufacturer) make a battery charger that can charge multiple batteries simultaneously?
Taro Beckwith is offline   Reply With Quote
Old January 19th, 2003, 11:41 PM   #24
Benjamin Lang
Posts: n/a
Battery Charger
I bought the Panasonic AG-DVX100 for a trip i'm taking to Thailand in a couple of days. I was wondering if anyone, knows about or had any experience with the battery charger. In the manual it states that it will automatically covert the voltage, with the proper plug, and will work without a seperate voltage converter.
I leave on the 21st...anybody know?
thanks
ben
Old January 22nd, 2003, 04:34 PM   #25
Today, all cam chargers circuits are based on SMPS (Switched Mode Power Supply) concepts. There is no problem and no extra cost involved to design them for voltages ranging from 90 to 240V/50 and 60hz (or higher).
Although I am not familiar with the DVX-100 I am 99.9999% shure the chargers are multivoltage ones.
Andre De Clercq is offline   Reply With Quote
Old March 20th, 2003, 03:16 AM   #26
Battery for the DVX100
Which model battery provides you the maximum record time for the DVX100?
Sam Looc is offline   Reply With Quote
Old March 20th, 2003, 03:25 AM   #27
Outer Circle
The 8 hour hip pack.
Old March 20th, 2003, 03:28 AM   #28
which one is this, where can I find it? Whats the model?
Old March 20th, 2003, 04:06 AM   #29
Outer Circle
VW-VDB5
$221.05
tim_selander@yahoo.com
Old March 20th, 2003, 04:12 AM   #30
thanks! Ist there a site or contact where I could get info and make purchase? Is the e-mail above the only contact I could get this? Will it fit a U.S. version of the camera? I found that its for the MX3000. What about the biggest one thats not hip pack? Thanx again.
