Can't get sound through my earphones at DVinfo.net
Old November 15th, 2004, 11:07 AM   #1
In the mist of shooting my feature I have discovered that I can not hear my sound through the headphone jack. While I do hear the hiss from amp, I can not hear the actual sound that I am recording. The levels read out on my sound, and the sound is there when I capture the footage to my NLE, but no matter what, I can not hear the sound through the headphone jack (even tried different headphones.) Is this problem common with the DVX100A? Or is there something that I am doing wrong? Thanks.
Glenn Gipson is offline   Reply With Quote
Old November 15th, 2004, 11:29 PM   #2
Make sure your monitor levels (buttons on top of you camera) are set where you can hear. If you cannot hear through your DVX speaker during playback, you'll not be able to hear through headphones while recording. I freaked out over this once myself!
Daniel Runyon is offline   Reply With Quote
Old November 15th, 2004, 11:32 PM   #3
Doh! That's exactly what the problem was. Thanks!
Old November 16th, 2004, 10:36 AM   #4
I just had that problem last week. After checking and rechecking to see that everything was plugged in, I finally got around to the monitor level. It's kinda scary.
http://www.horsefilms.com
"I like Mankato just a little bit better than any other town in the world." -Sinclair Lewis
Ryan Gohlinghorst is offline   Reply With Quote
Old November 16th, 2004, 03:47 PM   #5
<<<-- Originally posted by Ryan Gohlinghorst : It's kinda scary. -->>>
It's terrifiying. I thought I had fried something, but when I noticed that setting everything back to defaults fixed the problem, i made the connection. I too had tried another set of phones!
