MKH416, Shoe mount, and mattebox issues at DVinfo.net
Old August 6th, 2004, 02:23 AM   #1
I just received my DVX with a Chrosziel mattebox, along with my MKH416 mic. I had ordered the MZS CAM shock mount for the camera, but this seems awkward for this microphone, as it's a bear getting it in and out of the thing, and the foam windshield is rendered useless. I also got the sennheiser blimp for the boompole, but this doesn't fit the MZS CAM mount either.
If there is anyone out there with a similar mic, I'd love to hear your suggestions for getting it on the camera, up away from the mattebox.
Thanks.
Zareh Tjeknavorian is offline   Reply With Quote
Old August 9th, 2004, 09:31 PM   #2
I've got a DVX and a 416 and I use either a Rycote shoe-mount or the K-Tek KSSM... the K-Tek isn't supposed to be for mics as heavy as the 416, but so far it works great. The mic is never in frame either. With either the K-Tek or Rycote mount I can actually tilt the mic down and it's still out of frame.
If you want to take it one step better... get the Stratos bracket for $39 from B&H. I've got one of those too... it helps steady your shots and you can mount a mic way up off-cam if you like... I only use that part of the time though because the mic isn't in the way of anything in the shoe-mount anyway.
There you go... 3 guaranteed solutions.
Matt Gettemeier is offline   Reply With Quote
Old August 12th, 2004, 06:10 AM   #3
Thanks a lot Matt. I'm going to look into all of these options.
