F-Stops and video format - Page 2 at DVinfo.net
Old July 23rd, 2004, 10:53 AM   #16
Barry Wan Kenobi
The main updates to the chart are the inclusion of the numbers from 37 to 49 (the new close-focus numbers added by the 100A). Also I changed the infinity point to 95, Evin had 93 on the old chart but I find focusing on the moon, etc. that 95 is true "infinity".
The chart numbers for 37-49 are:
1' 11.5" ----- 37
2' 0.75" ----- 38
2' 1.5" ----- 39
2' 2.25" ----- 40
2' 3.25" ----- 41
2' 5.25" ----- 42
2' 6.75" ----- 43
2' 8.25" ----- 44
2' 10.25" ----- 45
3' ----- 46
3' 2.25" ----- 47
3' 4" ----- 48
3' 6.75 ----- 49
Old August 3rd, 2004, 08:36 PM   #17
<<<-- Originally posted by Tom Hardwick : In answer to your questions Jonathan, my answers would be 60i for the smoothest video, locked exposure a definate, and locked white balance a necessity. Don't white balance on a white or grey card as that will dilute the beautiful sunset etc... -->>>
OK.. no white or grey card, what do I WB on then? Just eye it? I don't have alot of experience.
If I lock EXP and WB would you just recommend building a profile for that? If the sun is peaking out of and going behind the clouds would you still keep things locked or make adjustment to WB, EXP or both?
-Jonathan
Jonathan Gentry is offline   Reply
