Convert Thin material to thick at DVinfo.net
Old March 29th, 2004, 09:31 AM   #1
hello everybody. I wonder how can i convert thin recorded material into thick video, so it looks well on the tv screen.
I coudl try to interpolate each field and blend it in vegas (as there are no fields we do not loose to much quality) but it gets to blur for me. Any other idea?
thanks!
Miguel Lopez is offline   Reply With Quote
Old March 29th, 2004, 10:24 AM   #2
Try adding a small amount of vertical blur in Vegas.
Barry Schmetter is offline   Reply With Quote
Old March 29th, 2004, 02:27 PM   #3
Barry Wan Kenobi
Most NLE's I've used have a de-flicker filter, which does exactly what you want. You'd typically use the de-flicker (or "reduce flicker") filter on a still photo that you'd scanned in, but it works well on thin-mode progressive also. In Premiere you'd choose "field options->reduce flicker", and in Vegas there's an option for flicker reduction in the resampling section.
Barry Green is offline   Reply
